Error while adding configuration context to SolidWorks Product Root Node
I am facing an issue when trying to add a Configuration Context to an EBOM item. To provide some background, the product structure (EBOM) was created in SolidWorks, and the model was subsequently saved to the 3DEXPERIENCE platform.
I attempted to add a Configuration Context to the model using the Product Structure Editor widget. However, I am unable to add the Model Version I created. When I try to do so, I can only see the version of the Model Version that supports Variants and Options, but the Evolution Effectivity Criteria option is not available.
I also tried performing the same operation using the native applications, but encountered the errors shown in the screenshots below.
I would like get some clarity on the following:
  1. Is it possible to add a Configuration Context to the root node of a SolidWorks-created EBOM?
  2. If yes, what is the correct procedure to achieve this?
  3. If this is not supported, is there an alternative approach or workaround to associate a Configuration Context with the EBOM?
Any guidance on this would be greatly appreciated.
Thank you in advance for your support
Product Structure
Error screen shots
