VBA V5 - SetGeometry on 5AxisCurveMachining
Hello everybody,
I am looking for a method to assign the main guiding contour to a Multi-Axis Curve Machining operation in vba (on catia v5 r20).
I can set : "auxiliary guiding contour", "relimiting elements" and" check element", but not the "main guiding contour"!
Below an extract of my code :
Dim Guide1 As HybridShape
Dim Guide2 As HybridShape
Dim Guide3 As HybridShape
Dim Guide4 As HybridShape
Dim MyMO As ManufacturingOperation
' Retrieve HybridShapes
Set Guide1 = MyPart.HybridBodies.Item(1).HybridShapes.Item(1)
Set Guide2 = MyPart.HybridBodies.Item(1).HybridShapes.Item(2)
Set Guide3 = MyPart.HybridBodies.Item(1).HybridShapes.Item(3)
Set Guide4 = MyPart.HybridBodies.Item(1).HybridShapes.Item(4)
' Append Multi-Axis Curve Machining with "Mfg5AxisCurveMachining" iMOTypeString
Set MyMO = MyMfgProgram.AppendOperation("Mfg5AxisCurveMachining", 1)
' Add Auxiliary guide curve => OK
Call MyMO.SetGeometry("AuxGuidingCurves", Guide1, MyMfgSetUp.GetProductInstance(), 0)
Call MyMO.SetGeometry("FirstRelimitingElement", Guide2, MyMfgSetUp.GetProductInstance(), 0)
Call MyMO.SetGeometry("SecondRelimitingElement", Guide3, MyMfgSetUp.GetProductInstance(), 0)
' Add Guide curve => KO, but I haven't error message
Call MyMO.SetGeometry("GuidingCurves", Guide4, MyMfgSetUp.GetProductInstance(), 0)
I have already searched in the DS Automation documentation, in vain... the method SetGeometry exists but is not fully detailed.
Thanks in advance.
Nicolas.
Answers 0
