After the customer has developed the process and allocated the machines and tools, they can use "Synchronize Data with Planning" to bring the machine settings defined in the process into the NC programming.
What is the difference between "NC Machine" used in the process and "3 Axis Machine" in CAM? What is the difference between "Tool Equipment" used in the process and "Cutting Tools" in CAM?
Can the terms "NC Machine" and "Tool Equipment" in the process be automatically converted into "3 Axis Machine" and "Cutting Tools" respectively?
Hello Leon,
- the "synchronize data with planning" command allow the user to generate a Manufacturing Product with raw, part to machine and requirements consumed in the operation, in the selected Manufacturing Cell. Only the command "insrert capable resources" allow the user to insert the resources (primary and secondary) already associated to the operation (header Operation object) inside the selected Manuf Cell
- NC Machine and Tool Equipment are generic resources used in other Delmia application like flow simulation, robotics, ergonomics. But those type of resources are not enought to be used in our machining apps, that's why RnD developped other dedicated type like 3 axis, 5 axis machine, cutting tools with the detailed insert, holder, accessories...
- a NC Machine or a Tool Equipment cannot be converted inside dedicated machining resources.
My recommandation is to associate dedicate machining resources directly in the header operation of the workplan to generate the programming context for the NC programmer.
@AL thank you for your answers @LW you can also follow the DELMIA process engineering community https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/community/swym:prd:R1132100503382:community:47
