Use existing ENOVIA document
Hi all,
I have a use case with a customer that wants to use already existing documents in ENOVIA as inputs inside xGEN & Visual Scripting. This is not Engineering Documents, just Documents like the ones you can browse in the Document Management WebApp. When I try to "Use Existing" in the Read Data from Sheet command it seems to only show Engineering Documents in the search by default.
Do you have any suggestions on how I can solve this or if it is even possible in the current release? I believe it worked in 25x, but I'm not 100% sure...
Btw, the "Use Existing" search option does not seem to be working in xGen as well, only get the following search error:
Answers 0
