Hi everyone,
I'd like to share NodeCode-FEA, a node-based visual editor for Abaqus that runs in the browser, similar to Visual Scripting in the 3DExperience. Instead of writing Python scripts or clicking through CAE dialogs, you connect nodes into a graph, and the results update live as you edit it.
The main capabilities:
Live link to Abaqus/CAE or Viewer: pick nodes, elements, faces and edges in the CAE viewport and use them in the graph. Results go back to CAE as native contours, XY plots, display groups and session fields. Nothing is installed in your Abaqus setup; the link exists only for that session.
Post-processing: open an .odb (or a whole folder of them) and pull field and history output. Compute components and invariants (Mises, principals…), filter by sets or thresholds, and reduce results to numbers (max/min/mean, with where the value was found). View contour plots, XY charts and tables. One Formula node covers the maths on numbers, fields and curves, and a field it makes (e.g. a utilisation Mises / yield) shows in CAE as a new variable.
Modelling: sketch, part, material and section, mesh, assembly, steps (static, buckling, Riks, heat transfer…), loads, BCs, interactions and jobs, all built live in Abaqus/CAE. The job's results sit in the same graph as the model.
Open an existing .cae or .inp as a graph, so a model you already have becomes a parametric one.
Parametric studies and reports: any setting can become an input, and a list of values runs a sweep. An "App" view turns the graph into a simple form (inputs → results) for colleagues who don't want to see the wires, and you can save it as an HTML report.
A library of ready-made examples to load and start from: post-processing graphs, modelling graphs (a bolt-hole flange, a bolted joint with preload and contact, mesh convergence…) and complete analyses solved in Abaqus and checked against theory (Euler buckling, Riks, heat transfer, natural frequencies…).
Developed with Abaqus 2025 and 2026 on Windows, ODBs need Abaqus 2024 or newer (Python 3). A built-in mock cantilever model lets you try it without Abaqus.
You can find it here: https://github.com/msolert/nodecode-fea
It's open source under the Apache 2.0 license and I'd really appreciate any feedback.
Thanks for reading!
The attached videos show post-processing and modelling live in Abaqus/CAE 2026:
NodeCode FEA is an independent project, not affiliated with or endorsed by Dassault Systèmes. Abaqus and SIMULIA are trademarks of Dassault Systèmes.
Thank you for sharing this, @MS!
