Converting from Engineering stress/strain to True stress/strain
A common issue when creating a metal plasticity model in Abaqus is the need to convert the test data from a typical tensile dogbone test to the appropriate set of data for defining the Elastic and Plastic parts of the material model.  Part of this conversion process is separating things into their Elastic and Plastics parts.  The most common way to define the plasticity (*plastic keyword in the input file) is with a series of data pairs of , but these stress & strain values in Abaqus must be in true stress / strain.  From the test we usually have engineering, or nominal, stress / strain values.  While our class Metal Inelasticity in Abaqus speaks to this issue, I though it would be helpful to demonstrate an Abaqus/CAE plug-in tool that helps process test data into the Elastic and Plastic parts needed to define the Abaqus metal plasticity model (here we are referring to the simple Mises isotropic model).
In the narrated video below, we review a few PowerPoint slides, show some test data in Excel, then demonstrate the Abaqus/CAE plug-in tool.  The plug-in tool can be downloaded from our Knowledge Base from QA00000009204, titled "Plug-in utility to convert nominal plastic stress-strain data", or search on the phrase "nom2true".  This video will play more clearly if downloaded first. Video file size is 53Mb, and about 16 minutes in duration.
Back to:  Material Modeling and Calibration - An Overview and Curriculum
Comments 7
SP
SP 2016-05-19
Hi!
I couldn't find where the plug-in is located. Is there some trouble on the post?
Regards
TD
TD 2016-05-19
Samuel,
I was hoping that everyone could go to our "Client Care" system: http://dsxclient.dsone.3ds.com
This is where our Knowledge Base exists.  I have attached the plug-in to this post.
Tod
SP
SP 2016-05-19
Hello Tod
I tried to access the link above, but I've received a message that this site is unable.
Although I'll check out my connections.
Thanks for the plug-in
Best Regards
YW
YW 2016-11-17
Dear Tod,
Thank you for the excellent talk!
The tensile test model (shown in 4:30 of your talk) nicely showed how necking happened in a test. I tried to do necking with Abaqus Standard but cannot make it happen (I guess some perturbation would be required to initiate it). If you wouldn't mind, could you kindly share the inp file of that model simulating the necking? Or, could you briefly hint us on the trick that you did to make the necking initiate?
Thanks,
Shawn
TD
TD 2016-11-21
Shawn,
That particular example used a UHARD user-subroutine for the power-law, so I doubt you would find it useful
There is an Abaqus Benchmarks Guide   1.1.9 Necking of a round tensile bar.  It comments about the slight perturbation that is often used in these types of problems as a 'trigger'.  I have also found that often encastre BCs at the grip area are enough of  a trigger mechanism.
YW
YW 2016-11-22
Tod - that's very helpful! Thank you so much.
SE
SE 2020-01-24
FYI - the link to the Knowledge Base article is here: https://kb.dsxclient.3ds.com/mashup-ui/page/document?q=docid:QA00000009204
