Abaqus blow molding simulation
I used Abaqus to build a blow molding simulation of a bottle. This kind of simulation helps you predict how thick the bottle wall will be at each point, so you can spot areas that are too thin or too thick.
It also helps you understand how temperature affects the blowing and find defects such as thin bottoms, uneven walls or incomplete filling of the mould.
This way, you can adjust the preform, the temperature and the blowing pressure on the computer before making real bottles, saving both time and material.
#Abaqus #BlowMolding #FEA #FiniteElementAnalysis #Simulation #ProcessSimulation #PlasticBottles #Packaging #Manufacturing #SIMULIA #DassaultSystemes #Engineering
Comments 1
BH
BH 2026-10-30
curious how you modeled the material. Did you use any non-linear visco-elasticity?
