Hello, makers,
Do you think, please, balance or perpetual motion is possible, whether the rose lower ball is placed under (first video) or above (second video) the low "skirt".
In the first case , i expect a load weighting on the upper plate to push on the lower rose ball, through the "skirt' so as to verticalize back the upper shaft .
In the second, the device needs to float on water and the top of the skirt to be shut, so as to allow an air pocket to lift it. I expect the rose ball to simultaneously push on the skirt from above, and may be association of both would produce a perpetual rotation. Requires, may be, wind to tilt the upper shaft. What do you think, please ?
