Hi everyone,
I am pleased to present our new 3D printer in the FABLAB : The Form1 from FormLabs (USA).
This 3D printer is one of the very first shipped in Europe, so let's get starting with a presentation of the Form 1 and enjoy the use of this printer in the 3DS FabLab soon!
Price as tested \\\$3,299 assembled, includes 1 liter resin
Build volume 4.9″×4.9″×6.5″
Print materials UV-cured resin
The Form 1 is the first entrant into the consumer SLA 3D printing market, built by Cambridge, Mass.-based Formlabs. As of press time, it’s also the highest-funded 3D printer on Kickstarter ever, raking in just under \\\$3 million. The Form 1 uses a UV laser beam steered by a mirror galvanometer system to selectively cure a liquid photopolymer film to form each layer.
The Form 1 works as well as it looks. The software interface is streamlined to match the hardware; the process really is as simple as loading the file and hitting Print (or “Form,” as they call it). The PreForm software also has a unique, built-in feature that notifies you if the model has errors and helps you orient it correctly for printing. More experienced users can tweak options ranging from layer resolution to support structure parameters.The instructions are simple and clear. Between them and the intuitive interface, we had our first object printing in less than 30 minutes out-of-the-box.
We tested the Form 1 using the bundled clear resin (an opaque grey is also available). The software offers three different resolutions: 100, 50, and 25 microns. The finer options dramatically increase print times.
(Click to zoom)
We ran prints of a designed Dassault Systèmes iPhone case. The Form 1 never hiccupped. The parts were absolutely beautiful, the layers, even at the low setting, barely distinguishable.
We found the cleanup process a bit of work, as prints stuck really well to the platform. A small toolkit is bundled with the printer for cleaning, handling and maintenance, which is a nice touch.
At the 3DS FabLab we have to colors of resin:and
All in all, Formlabs has created a modern marvel in its debut 3D printer — a thoroughly enjoyable user experience and fast, high-quality prints. So post your projects on the Madein3D community and get a chance to print your prototype on this new machine!
Source: makezine.com & Madein3D team
