3D Printer enclosure using Ikea Lack table
Why do I need an enclosure for my 3D printer ?
  • Stable printing environment – Drafts can negatively impact your print. An enclosure will keep the temperature stable and high. Big differences in ambient and printing temperatures can lead to warping and shrinking of the printed object, especially when printing with ABS. Layer adhesion may also improve with higher ambient temps.
  • Reduce and contain smell – Some filaments (looking at you, ABS!) can release unpleasant fumes during printing. An enclosure will contain these fumes, and you can quickly vent them outside through an open window when the print finishes.
  • Noise reduction – As if you needed the MK3 to be any quieter  But another level of sound isolation can’t hurt, especially if you place the enclosure next to your work desk or in a living room.
  • Dust collection – The bearings and smooth rods will appreciate the reduced amount of dust that settles on your printer.
  • It’s fun to build
However, if you’re not printing with ABS or other high-temperature filaments that suffer from warping, you won’t see much of a difference. You might actually want to keep the enclosure open with, for example, PLA to ensure there’s enough cool air around the printer for the part cooling fan.
Using Ikea Lack as an enclosure is the most popular choice among the 3D printing community. If you search online, you’ll find dozens of Ikea Lack enclosure designs. The table can be bought for under \\\$10 and has almost the perfect size for Prusa printers. You can stack the tables on top of each other to create bays for multiple printers, or use one as filament and tools storage. Even though some of the existing enclosure designs are pretty good, we wanted to give it our own spin.
Advantages of our enclosure
  • PSU placed outside in a clip-on holder, but easily placed back if you need to move the printer
  • LED lighting connected to the printer’s PSU
  • Hinges built into corner extensions
  • Double-door opening
  • Individual tables can be lifted at any time
Construction
Electronics
Printed parts
