2x72” Belt Grinder
As part of my end-of-study project and due to the lack of means to carry out the polishing operations in the workshop of the mechanical engineering department of faculty . This gave rise to the need to design and manufacture a belt grinder machine
The design phase took 2 month using variety of functions in solidworks wish helped improve the design along the way
The Fabrication Phase the fabrication has passed through different fabrication methods starting from machining the parts in mill and drill machines to weld it using arc welding, semi-automatic Mig/Mag welding.
The system can work in two positions vertically (normal position) with 5cm width of the abrasive belt and horizontally with 30cm width of the abrasive belt for long parts.
due to its adjustable angle table The System could create chamfers. With a variety of choices and degrees of grinder belt roughness for different uses.
