SHEET METAL
Hello Everyone,
I recently learned new skills on SOLIDWORKS which is Solidworks Sheet Metal. Sheet Metal is a very highly proficient tool used in Industry.
Some of the key sheet metal features in SolidWorks which I learned:
Base Flange: This feature creates the initial flat sheet metal part that can then be bent or formed into a desired shape.
Edge Flange: This feature creates a flange along an existing edge of the sheet metal part, which can be used to create corners or other features.
Hem: This feature creates a folded edge along the edge of a sheet metal part, which can be used to add stiffness or a finished look.
Bend: This feature allows you to bend the sheet metal part to a desired angle or radius.
Unfold: This feature allows you to flatten a bent sheet metal part back to its original flat state.
Fold: This feature allows you to bend a sheet metal part back to its bent state after it has been flattened.
I have designed this on Solidworks using Sheet Metal Tool and Rendered it on Solidworks Visualize Professional.
SOLIDWORKS
#manufacturing #environment #solidworks #solidworks2023 #dassaultsystèmes #sheetmetal
