I am facing a problem with software installation, which is as System Check Warnings
i have inter the correct serial number key, but I am facing a problem, which is as "your serial number does not entitle you to SOLIDWORKS Composer 2023. Verify that the number is correct. If your license is new, you may want to try again later. If you continue, you will still be able to choose the products you want to install, but you will not be able to download any installation files. You will need to provide a complete set of download source files or a DVD from which to install."
please sugest me the solution of these typo problem
0
