SW Tip - Dangling Dimension
Good morning,
Here is your weekly SOLIDWORKS tip.
Comments 2
DM
DM 2025-12-11
This is nice for precision reattachment and getting the gap in the dim from the edge of the part. I just have a hard time telling between the dangling dims and the deleted dims that do not allow the reattachment.
AS
AS 2025-12-13
In addition to Betty's tip:
The “Reattach” function in the right-click menu was introduced in SOLIDWORKS 2024.
This function is only available for dimensions created in the Drawing, not for imported “model items” or dimensions deleted in the model.
In addition, “Reattach” also works with valid dimensions, not just detached dimensions.
Which dimension origins can be reassigned depends on how the dimension was created. For example, the behavior is different if a line was dimensioned over 2 points or directly over the line segment.
(Also new in SWX2024: Highlighting Referenced Elements, i.e., you can see the associated elements)
Tip: If there are multiple origins, you can use the “Enter” key to define the “red cross” for the next origin and ‘Esc’ to return to the previous “red cross.”
