Study Setup and Simulation Results
Shear Stress in the Beam Forces List
Read the shear stress on each beam without calculating it by hand. The List Beam Forces stress table now includes dedicated Shear Dir1 and Shear Dir2 columns beside axial, bending, and torsional stress.
Pinned Study Details
Keep study setup information in view while you review results. Pin the details window for a study, fixture, or load, and it stays open over the plot, so you don’t switch back to the study tree to check a setting.
Summation Sensor
Get one total for a simulation result across the entities you choose. Add a Simulation Data sensor, pick a quantity such as connector force, select the entities (for example, all bolts), and read the summed value. Use it to see the combined load on every bolt without adding up values one by one.
Bonded Contact Stress Results
See where your bonded interfaces carry load. Plot normal and tangential stresses at bonded contacts, and display them as a color plot or as vectors that show the direction of the load. Available for bonded interactions that use the Surface to Surface formulation.
Angular Deformation Plots
See how much your model rotates about any axis. In a Displacement plot, choose Angular Rotation, select an axis, and plot the result in degrees or radians.
Total Force on Beams
Apply one force across several beams without calculating each beam’s share by hand. The Total option distributes the force among the selected beams in proportion to their lengths. Before, you could only apply a force to each beam separately.
Default Shell Type for New Studies
Set Thin or Thick as the default shell type once, and every new study starts with your choice. Go to Default Options > Mesh > Shell type.
