The following enhancements apply to SOLIDWORKS Simulation Designer, SOLIDWORKS Simulation Engineer, and SOLIDWORKS Simulation Analyst.
Meshing
Tetra/Tria Cross-Quality Analysis
Detect triangle mesh elements attached to poor-quality tetrahedral elements, closing the gap between tetra and tria quality analysis. Review problem regions earlier in the meshing process instead of discovering them during the solve.
Condense Nodes Position Control
Define the exact position of the merged node when you condense nodes in mesh editing. Use a slider between the two original node locations instead of a fixed midpoint. Choose whether the new node projects onto the mesh support surface or sits on the straight line between the original nodes.
Improved Bead Meshing Rules
Define the number of elements used in each bead pattern instead of relying on an automatic count, for both Automated Meshing and the Surface Mesher's Bead Mesh specification. Detect beads more reliably across both tools.
Expanded Bead Mesh Specification
Define the number of layers in a bead mesh, not just its size, for finer control over the result. Apply bead mesh specifications across multiple support domains without manually reworking the topology to make it compliant.
Results
Immersive VR Results Exploration
Review your full simulation results in VR. Switch between saved Scenes, probe results, and reposition and reorient slices, cut surfaces, and streamlines, all without leaving the headset.
The following enhancements apply to SOLIDWORKS Simulation Engineer and SOLIDWORKS Simulation Analyst.
Model Build
Numerical Sizing for Spatial Groups
Define the exact size of a box or sphere capture volume in the Spatial Group command by entering values, so you control which nodes and elements the group captures. This brings Spatial Groups in line with the sizing control already available in Automated FEM sub-modeling.
The following enhancements apply to SOLIDWORKS Simulation Analyst.
Model Build
Shareable Contact Interaction Templates
Save Model Based Contact properties as a template you can reuse and share, then apply the same contact interactions across multiple simulations instead of redefining them each time. This works the way mesh and connection templates do.
