SOLIDWORKS Plastics Standard, Professional, and Premium - R2027x GA
Materials
Plastics Materials Database Update
Run your simulations on the latest manufacturer data. Compared to SOLIDWORKS Plastics 2026 SP0, the database adds 144 material grades, updates 51, and removes 29 obsolete grades.
ManufacturerNew gradesUpdated gradesRemoved grades
RadiciGroup High Performance Polymers73241
Covestro29227
MOCOM2400
Solvay Specialty Polymers15519
EMS-GRIVORY202
Trinseo100
Total 144 51 29
Project and Data Management
Custom Project Folder (R2026x SP4/FD04)
Store your study results in a project folder you choose, separate from your CAD files folder. Because your simulation data sits in its own folder, you can sync it with your PLM or PDM system without pulling in unrelated CAD files.
Save to 3DEXPERIENCE for Plastics Data(R2026x SP4/FD04)
Use Save to 3DEXPERIENCE to store and manage your SOLIDWORKS Plastics project data on the 3DEXPERIENCE platform.
Pack and Go for Plastics Studies (R2026x SP2/FD02)
Include your SOLIDWORKS Plastics studies when you use Pack and Go, so the package you send has the parts, assemblies, and simulation results together in one folder or ZIP file. File references stay intact, and the Plastics results are saved in a subfolder under the document’s folder.
Results Review
Reynolds Number Result in Cool Simulations
Check whether the flow in your cooling channels is turbulent, using Reynolds number results from your Cool simulation. Use the results to adjust flow rates, and balance pressure drop against heat transfer efficiency, so your mold cooling performs the way you designed it.
Multi-Point Results Probe
Query result values at multiple points across your model, and keep the same query positions as you switch between results, so you compare several areas of interest without redefining the probes for each result. Probe mode is on by default. It isn’t available for Air traps, Weld lines, or Velocity Vector at End of Fill results.
Solver Performance and Accuracy
GPU-Accelerated Fiber Orientation Analysis
Run fiber-filled polymer simulations with your computer’s supported NVIDIA GPU working alongside the CPU, and cut fiber orientation calculation time by up to 20%. GPU acceleration is on by default, so you don’t need to change anything. Your results depend on your model, mesh, material, and GPU hardware.
2nd Order Solve for Fill and Pack Analyses
Get more accurate Fill and Pack results on models with relatively coarse meshes by turning on the 2nd Order Solve option. Use it when a finer mesh is hard to generate, or when you want a shorter analysis time and still want results closer to a finer mesh. On models with well-refined meshes, you’ll see little to no difference between the default and 2nd Order Solve methods.
