SOLIDWORKS PDM Standard and Professional - R2027x GA
SOLIDWORKS PDM Compatibility with Newer SOLIDWORKS Releases
Starting with SOLIDWORKS R2026 SP3/FD03, upgrade SOLIDWORKS to a newer release and keep working with your current version of SOLIDWORKS PDM, so you don’t have to upgrade your PDM vault and clients at the same time. This applies to single-user SOLIDWORKS Design licenses.
M
Single Sign-On
Improve security, simplify administration, and reduce password fatigue. Sign in to vault views with your organization’s credentials and MFA methods instead of a separate PDM or Windows® username and password. Choose from five identity providers: Auth0, Okta, Keycloak, Microsoft Entra ID, and AWS IAM Identity Center. This applies to SOLIDWORKS PDM Professional only.
Task and Task Host Management
Generate PDFs and output files faster. Assign tasks to designated host machines with an improved algorithm for faster processing. Distribute PDFs and other output files across available computing resources.
Date-Based Replication Criteria
Replicate only the files modified after a date you choose, so scheduled archive replication skips older files. The date filter applies to scheduled replication. On-demand replication isn’t affected. This applies to SOLIDWORKS PDM Professional only.
Column Set Support in Web2
View the custom column sets your vault administrator sets up for the Web2 client’s List View, so you see the file data you need without adding columns yourself. You can use column sets if your administrator has granted you the permission. This applies to SOLIDWORKS PDM Professional only.
Days in State Variable Shown in Contains and Where Used
See how many days a file has spent in its current workflow state, in the Contains and Where Used views, so you can spot files stuck in a state without checking each one.
Option to Overwrite Toolbox Versions
Eliminate unnecessary versions of Toolbox files by automatically overwriting the previous version when new configurations are added.  Reduces reference data for better performance and saves disk space.
Web2 Preview Fractional Unit Display
Visualize measurements using fractional units for better readability. This applies to SOLIDWORKS PDM Professional only.
Web2 Preview Component Display Options
Easily add important component information such as Description, Configuration Name, and Component References to the Components display panel for quick reference.  This applies to SOLIDWORKS PDM Professional only.
