Fabrication and Machining
Post-Processing Included with Machining
Create ISO code from your NC program using predefined post-processors, at no additional cost. Select a post-processor for your machine, generate the code, and review it right away. Need a different output? Create your own post-processor and cut machining setup time.
Laser and Waterjet Cutting
Deliver faster, more accurate laser operations with a redesigned cutting head interface that cuts setup time and reduces errors. Native point-to-point support removes programming workaround, while integrated part marking strengthens traceability without extra handling steps. Circular contours now output as holes, producing cleaner results and leaner NC code across every job.
Multiple Pocket Definition
Define multiple pockets in a single Pocketing operation, the same way you already can with other milling operations. This keeps your workflow consistent and reduces the number of separate operations you need to set up.
Rotating Stock Visualization
Detect collisions reliably on non-symmetric stock, such as castings, with a new rotary stock representation that rotates along with the fixtures instead of staying fixed. Gain a clear, at-a-glance view of material removal as you program, cutting programming time and helping new users ramp up faster.
