Model and Mesh Setup
Leak and Gap Sealing for Internal Analyses
Find and seal leaks and gaps in your model with Close Thin Slot and Fill Thin Slot, so your internal analysis runs on watertight geometry without manual repair. Check the sealed cells in the Mesh Plot in Cells mode before you run.
Feature Parameter Editing from Components
Edit the parameters of features that come from components, directly from the top-level assembly, without opening each component. Change each component instance on its own. Requires the Electronics Cooling module.
Local Mesh Settings Based on Absolute Cell Size
Define a local mesh refinement as an absolute cell size, so it stays the same whatever your global mesh settings are. Reuse a library component in several models and get the same mesh resolution on that component every time.
Formula-Based Angular Velocity Dependencies
Define angular velocity with a formula that uses time, project parameters, or simulation goals, so your rotating parts run at the speed your design needs at every point in the simulation.
Direct Editing of Material Priority Values
Set a material’s priority by typing the value in the table, instead of moving it up or down one step at a time.
Electronics Cooling
ECXML File Import Support
Import ECXML (Electronics Cooling eXtensible Markup Language) files directly into your simulation, so you can set up an electronics cooling model from existing data without rebuilding it.
Calculation Preparation for Large Two-Resistor (2R) Models
Start your calculation sooner on large electronics models. Preparation is faster for models with 500+ two-resistor (2R) components and over one million mesh cells. Requires the Electronics Cooling module.
“Rebuild All” Feature In Component Sub-Projects
Rebuild and save every subassembly that contains From Component sub-projects in one operation, instead of opening and rebuilding each one. Requires the Electronics Cooling module.
Maximum and Minimum Temperature Columns in Component Explorer
See the maximum and minimum temperature of each component in dedicated columns, so you spot the hottest components without opening a separate result for each. Requires the Electronics Cooling module.
Component Explorer Loading Speed
Open and navigate across complex simulation projects in the Component Explorer up to 2× faster on large simulation projects.
