Our Favorites
- Know right away when a collaborator modifies a document you have open, so you don’t overwrite their work or build on an outdated version.
- Import full-color point clouds to design in real-world environments.
- Save your designs to the current release or a previous one, with a preferred save version you set once.
- Maintain consistent fillet width with the Chord Width option for edge fillets.
- Create stamped features directly across sheet metal bends.
User Experience
Keep Recent File Lists Relevant
Find relevant documents faster by keeping recent document lists focused on your current work. Select and remove multiple documents from the Welcome dialog’s Recent Documents tab, or remove individual documents from File → Open Recent.
Workspace Settings
See which System Options and Document Properties changed in this release without leaving the Options dialog. You can also choose whether the FeatureManager design tree keeps its own width for each model or uses one width across all models, so you stop resizing it every time you switch documents.
Save To Version
Save your designs to the current release or a previous one, and set your preferred save version once. Files can keep their current version when you save, unless they are more than two releases old, in which case you choose a valid version at save time.
Parts, Assemblies, and Drawings
Import Full-Color Point Clouds
Design with greater speed and confidence in real-world environments by importing massive, full-color point clouds that make it easier to distinguish objects and understand surrounding conditions. The ability to work with full color point clouds helps eliminate the slow and error-prone tasks of manual measurements on-site and the recreation of your environment in CAD.
Chord Width Option for Constant Width Edge Fillets
Maintain consistent fillet width with the Chord Width option for edge fillets. Get the exact fillet geometry your design needs without workarounds.
Stamped Features Across Sheet Metal Bends
Model sheet metal parts accurately by creating stamped features directly across bends, simplifying design and eliminating time-consuming workarounds.
Locking Rotation in Coincident Mates
Fully constrain a component with fewer mates. Lock rotation in a coincident mate between two linear edges, axes, or lines, so you don’t add another mate to stop the component from spinning. This helps with conical geometry, such as countersunk holes and fasteners.
Weld Beads Across Multibody Parts
Define welds faster and with less manual effort by automatically identifying intersecting geometry and applying weld beads across multibody parts.
Skip Rebuilding Select Drawing Views
Exclude selected views from rebuilds so large drawings update faster when working. Views you skip don’t update until you choose to rebuild them.
Sheet Format Lock
Lock a sheet format so no one changes it by accident. Your title blocks, borders, and approved layouts stay as your drawing standard defines them.
Standards-Compliant Zone Symbols
Communicate surface texture and geometric tolerance requirements more clearly with standards-compliant areal zone symbols, helping ensure design intent is accurately understood downstream.
Customizing Profile Tolerance Tables
Document company and project-specific tolerance requirements more easily with customizable profile tolerance tables, improving flexibility and consistency in manufacturing documentation.
Opening Models in the Referenced Display State
Open a model from an assembly or drawing view and see it in the same display state you were looking at. You don’t switch display states again after the part opens.
Collaboration and Data Management
Document Change Alerts
AI Access Without Platform Data Management
Use LEO and other AI capabilities without storing or managing your data on the 3DEXPERIENCE platform. If you use a device-licensed SOLIDWORKS Design or Collaborative Designer for SOLIDWORKS, you can now work this way too.
Updating Bookmark Folders Content to Latest Revision
Applies to Collaborative Industry Innovator
Bring every item in a bookmark folder up to its latest revision in one step, so you always work with current content.
3DEXPERIENCE Physical Products and Representations
Align SOLIDWORKS Design with 3DEXPERIENCE data concepts, making physical product and representation workflows clearer and easier to manage.
Loading Indicator for Find Similar Search
See that your PartSupply search is running while Find Similar retrieves your results, so you know the system is working and don’t wonder whether to search again.
Managing Minor Changes for Released Objects
Fix attribute errors on a released revision without creating a new one, then compare it with the previous revision to verify exactly what changed, all under change control and fully traceable.
Simulation Parameter Publishing
Publish parameters only when your simulation workflow needs them, so your saved data carries only what you use. Your physical products also get a stable ID that stays the same across interchangeable members of a CAD family.
Routing
Wires, Cables, and Harnesses as Native Electrical Parts
Create each wire, cable, and harness as its own part with electrical properties built in. You track and document every one individually on the 3DEXPERIENCE platform, instead of treating them as part of a larger assembly.
Rendering
Volumetric Effects and OpenVDB Import
Render smoke, fire, and clouds that show light passing through and scattering within them, instead of reflecting off a surface. Import ready-made OpenVDB volumes into SOLIDWORKS Visualize, so you don’t build these effects from scratch. OpenVDB was developed for the film industry to efficiently store and render large, sparse volumes, and it is now a staple in VFX pipelines.
