Our Favorites
- Ask LEO for a drawing, see a preview right away, and refine it in plain language until it’s right. (Manufacturing Documentation)
- Automatically generate a mean model from your design, adjusting dimensions to the middle of their tolerance bands without any manual remodeling
- Know your part can be milled before it reaches the shop, with a specific fix for every warning or failure. (Design Validation)
- Find out why your assembly is slow and how to fix it, with the cause, the action, and the expected result. (Assembly Optimization)
- Describe a task to LEO and get a macro, without writing code. (Engineering Guidance)
Drawing Preview from Your First Request
Ask LEO for a drawing and see a preview right away. Avoid long lists of settings and get to the result faster.
Try it:
Create a drawing for this part.
Instant Drawing Refinement in Plain Language
Describe a change in plain language and see it in the preview right away. Repeat until the drawing is right.
Try it:
Use ANSI drafting standards and plus-minus tolerances.
Automatic Hole Tables
Detail parts with many holes in one hole table. LEO adds a table when the part needs one, so shop-floor teams find every hole position and label in one place. You can also ask LEO for a hole table at any time.
Multi-Sheet Drawing Layout
Keep every view readable without crowding one sheet. LEO places flat patterns, bend tables, and exploded views on their own sheets.
Generate Drawings for the Right Parts
Generate drawings only for the parts you need, with no extra drawings to delete afterward. Ask LEO to include:
- Released or In-Work parts
- Parts you or a teammate created
- Parts changed today, last week, or within a date range
Automatically exclude standard hardware and parts that already have drawings.
Try it:
Create drawings for all my released parts.
Design Validation
Design for Manufacturing Guidance
Know your part can be milled before it reaches the shop. LEO checks designs for 3-, 4-, and 5-axis CNC milling and flags sharp internal corners, thin walls, undercuts, large shallow bores, angled surfaces, and more. For every warning or failure, LEO explains why the check was triggered and recommends a specific fix, so you can resolve issues in the model and avoid costly rework later.
Mean-Tolerance Model Generation
Generate a model that hits the middle of your tolerance band, with no need for manual re-modeling. LEO reads the tolerances and datums in your CAD and PMI, recalculates each asymmetric dimension to its mean value, and creates an unlinked mean-model configuration for you.
Generative Assembly Structure
Generate and save assembly structures in a single step with the ability to import and export CSV files and make easy template changes, while preventing unintended large-scale structure edits.
Improved Assembly Performance Analysis
Find out why your assembly is slow and how to fix it. LEO analyzes your assembly, explains the cause of each slowdown, and gives you the action to take, with the exact menu path and the result to expect. Select Chat with LEO in the Performance Evaluation dialog to ask follow-up questions.
Mass and Material Insights
Answer design review questions without checking each component manually. Ask LEO about mass, density, and materials, and identify missing material assignments that could affect the results.
Try it: "Which steel parts contribute the most mass to this assembly?”
Easier Macro Creation
Save time on repetitive work and reuse the same process across designs. Describe the task to LEO to create a macro without writing code yourself.
real world test...Leo is thinking for a loooong time, end up with to many dimension that you of course "easily" can delete, views is not arranged as you want them. SO you end up spending more time to make a simpel drawing yourself than using AI
