Introducing the New SOLIDWORKS Milling Professional Role
The new SOLIDWORKS Milling Professional role combines the functionality of the following DELMIA roles into a single role:
NC Mold & Die Programmer
NC Knowledge Manager
SOLIDWORKS Milling Professional is a powerful, integrated 3-axis to 5-axis milling CAM solution with machine simulation. Designed for manufacturers and machinists, it enables you to create CNC toolpaths directly from 3D models without the need for external file transfers to neutral formats.
- Complete 2.5 & 3-axis milling solution for molds, dies, and tooling, including specific cycles dedicated to hard material strategies for reducing machining times
- Capitalize on company know-how to reduce programming time by reusing already existing programs
- Validate NC programs early in 3D to detect and prevent possible machining errors
- Streamline collaboration between designers and NC programmers to improve engineering efficiency
- Create and use customized templates to reduce potential errors for NC programmers
Introducing the New SOLIDWORKS Turning Professional Role
The new SOLIDWORKS Turning Professional role combines the functionality of the following DELMIA roles into a single role:
NC Prismatic & Mill-Turn Machine Programmer
SOLIDWORKS Turning Professional is a complete CNC turning CAM solution designed to work seamlessly with SOLIDWORKS CAD. It empowers machinists and manufacturers to create accurate, efficient turning toolpaths directly from their 3D models, with no need for file export or data duplication.
- Complete 2.5-axis milling and turning programming solution in a single environment
- Create a Wire EDM operation to program up to 4-axis machines for faster processing times and superior surface finishes for even the most complex of part geometries
Introducing the New SOLIDWORKS Milling + Turning Premium Role
The new SOLIDWORKS Milling + Turning Premium role combines the functionality of the following DELMIA roles into a single role:
NC Mill-Turn Machine Programmer
Shop Floor Equipment Engineer
SOLIDWORKS Milling + Turning Premium is a comprehensive multitasking CNC programming solution designed for complex parts that require both milling and turning operations. Fully linked to SOLIDWORKS CAD data, it enables you to create synchronized machining programs directly from 3D models, ensuring that design and manufacturing remain perfectly aligned.
- Supports multi-axis lathes, sub-spindles, live tooling, Y-axis operations, complete 5-axis advanced operations, plus robot programming for machine tending
- Streamline collaboration between designers & NC programmers to improve engineering efficiency
- Includes specific cycles dedicated to hard material strategies that reduce machining time
- Build a virtual twin experience of factory machines using any CAD data
