Drafting
Associative Pattern (Path Option)
Distribute objects along a path, such as a curve, spline, or polyline, without copying and aligning each one by hand. The pattern stays associated with the path, so it updates when you change the path.
SMARTCALCULATOR Palette
Calculate geometric values in a palette inside your drawing, so you don’t leave the drafting window to do the math. Perform unit conversions or gather distance, area, or circumference all in one palette.
Available only in DraftSight Premium and above.
Angle Input Override
Enter an exact angle to lock your cursor to that direction, so you don’t calculate coordinates to draw at an angle.
ENTERPOINT Command
Enter exact 2D absolute or relative coordinates in a dialog box or at a prompt, with no command-line syntax or prefix symbols to remember.
PROPERTYPAINTER Command
Copy layer, color, lineweight, linestyle, linescale, transparency, hatch, and dimension formatting from one entity to multiple entities in a single operation, including entities in other open drawings.
Data Extraction and Automation
DATAEXTRACTION: XLSX Export
Export CAD attributes directly to an XLSX spreadsheet, so you don’t retype data or reformat it in Excel.
FIELD Command: Formula Support
Add formulas to fields in your drawing, so calculated values in tables and schedules update when your design changes.
Collaboration and Workflow Efficiency
XREF Notification
Get a notification when a drawing you’ve linked as an external reference changes, so you know your base plan is out of date before you keep working on it.
MVSETUP Command
Set up drawing limits, viewports, and a title block for a new sheet in one command, so you don’t build each layout by hand.
Disabling Read-Only Messages
Turn off the read-only message when you open a file, so you don’t dismiss the same prompt every time.
File Security and Integrity
DWG Digital Signatures
Sign your DWG files with a digital signature to protect your intellectual property and comply with external delivery standards. Verify a signed file to confirm who signed it and that no one has changed it since.
SAFETYOPTIONS Command
Control which executable scripts can run in your drawing environment, so only the code you approve runs on your users’ machines.
DRAWINGRECOVERY Palette
Launch the Drawing Recovery palette automatically after an unexpected system or application crash to list backup (.bak) and autosave files. Preview, compare, and restore the most recent recovery file version to minimize lost drafting work.
User Assistance and System Diagnostics
Contextual Help Integration
Launch the Online Help Palette and access context-sensitive feature descriptions, option definitions, and step-by-step instructions directly in the palette without manual searching.
Rx Tool
Run a standalone diagnostic to find what’s causing graphics and performance problems on your computer, without opening the application first. Prevent extended downtime and speed up troubleshooting when submitting service requests.
The following enhancements apply to DraftSight Mechanical.
Mechanical Detailing and Annotation
Power Dimensioning Dialog Box
Set the fit, tolerance, and symbols for a dimension in one dialog box during annotation placement, so you don’t open a separate dialog for every setting.
Dimension Overdrawn Dialog Box
Flexible layout controls let you replace, break up, or offset dimensions in one click.
AMNOTEEDIT: Double-Click Editing
Double-click a note to edit it, instead of opening a menu or typing a command.
Bill of Materials (BOM) and Manufacturing Data
AMFITSLIST Command
Generate a table of fits and tolerance data in your drawing, instead of looking up each value and typing it in.
Spreadsheet-Style Copy and Paste for Parts Lists
Copy and paste tabular data directly into a parts list, instead of typing each cell.
Result Bar for Parts List Dialog
See totals for your parts list in a result bar, so you verify quantities without counting rows.
The following enhancements apply to BIM Module in DraftSight Premium only.
BIM Documentation and Representation
BIM Material Library
Assign a material to a component and get the cut and projection hatches your drawing standard calls for, without setting a hatch on each view by hand.
BIM Stair 2D Representation (IFC)
Get 2D stair graphics directly from an IFC model, without redrawing or cleaning up the stair by hand.
BIM IFC Column Grid Support
Bring the structural grid from an IFC model directly into your drawing, instead of redrawing it by hand to locate columns and elements.
Curtain Wall Dimensioning
Dimension curtain walls and modular facades automatically, instead of measuring and placing each dimension by hand.
BIM Coordination and Data Management
RELOAD-FROM: Annotation-Preserving Reload
Reload an updated federated BIM model and keep the 2D annotations and layouts you’ve already added, so you don’t redo them.
BIM Advanced Reference Manager
Reuse your standard details across multiple BIM projects by referencing them, instead of copying them into every project file.
