Designing a Simple Phone in xDesign
Learn how to use the basic features of xDesign to model a simple phone. This will form the starting point of the phone holder assembly.
What is covered?
- Project Introduction: The goal of the project is to create a representation of a phone to be used in an assembly for a phone holder. [00:13]
- Getting Started with xDesign: The video shows how to create a new component, name it, and save it. It also introduces the user interface, including the Design Manager and Action Bar. [00:38]
- Modeling the Phone Body: Instructions on how to create the basic phone shape by sketching on the YZ plane, using a center rectangle, and then using the Extrude tool. [01:31]
- Adding Details: How to add details to the phone, such as fillets for rounded corners and raised buttons created by sketching and extruding. [04:08]
- Advanced Modeling Techniques: The video demonstrates using the Mirror command to duplicate features and the Extrude Cut tool to create a cutout for a charging port. [07:04]
- Final Steps: The video concludes with saving the completed model and a preview of the next video in the series. [08:06]
Step-by-Step Instructions (AI-generated from video transcript):
Based on the video at https://youtu.be/772K-H7AoEE, here are the step-by-step instructions for creating the phone model in SOLIDWORKS xDesign:
Part 1: Creating the Base Rectangle
- Start a new component, name it, and save it in a collaborative space.
- Select the YZ (front) plane and start a new sketch.
- Use the Center Rectangle tool to draw a rectangle centered at the origin.
- Use the Dimension tool to set the height to 175 mm and the width to 85 mm.
Part 2: Extruding the Rectangle to a 3D Solid
- Use the Extrude tool from the Features toolbar.
- Select the sketch as the profile.
- Choose the Midplane option for Direction 1 to keep the model centered.
- Set the extrusion depth to 10 mm and complete the command.
Part 3: Adding Fillets to the Edges
- Select an edge of the phone body and choose the Fillet command.
- Accept the Design Assistant suggestion to select the other three corners.
- Set the fillet radius to 12 mm.
- Add fillets to the front and back edges with a radius of 2 mm, using the tangent propagation option.
Part 4: Creating the Side Buttons
- Start a new sketch on one of the side faces of the phone.
- Use the Slot tool to draw a slot for the button, aligning it vertically with the origin.
- Dimension the slot to a length of 40 mm and a radius of 3 mm, located 30 mm from the top edge.
- Extrude the slot 1 mm outward from the face.
- Add a 1 mm fillet around the extruded button.
Part 5: Mirroring the Side Button
- Show the planes from the View menu.
- Use the Mirror command from the Features toolbar.
- Select the plane that runs through the middle of the phone as the mirror plane.
- Select the extrusion and fillet features of the button to mirror them to the other side.
Part 6: Creating the Charging Port Cutout
- Start a sketch on the bottom face of the phone.
- Use the Midpoint Center Line Slot tool to draw a slot centered at the origin.
- Dimension the slot to a length of 10 mm and a radius of 3 mm.
- Use the Extrude Cut tool to create a cutout 5 mm deep.
Part 7: Saving the Model
- Save the completed phone model to the platform.
More Info
Roles:
SOLIDWORKS xDesign
Tags:
beginners guide 3DEXPERIENCE platform Browser Based CAD
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
