🏃‍♀️ 3DEXPERIENCE Works | Getting Started Guide
Welcome to the 3DEXPERIENCE Works Getting Started Guide
This guide has been created to help you get started with the 3DEXPERIENCE platform and your 3DEXPERIENCE Works roles and apps.
As a new 3DEXPERIENCE platform user, you will either be an Administrator or a Member
Choose your path to get started with 3DEXPERIENCE Works Roles and Apps:
Getting Started | Admin Path
I am the Administrator of my company's platform
This path walks you through the basics of setting up your company's platform. You will learn what options are available to you and how best to get started.
Getting Started | Member Path
I am a Member who will use the Roles and Apps of my company's platform
This path focuses on how you can use the 3DEXPERIENCE platform and the Roles and Apps assigned to you.
 **I am both the Administrator and Member who will use the Roles and Apps. For this, you should follow through both paths!
As a member or an administrator, this guide will help you get started, no matter what type of customer you are, Commercial Customer, Makers, or Academia.
This guide is intended to be used as a reference at any time! To get the best out of the 3DEXPERIENCE platform for your business you should work with your Reseller Partner to successfully onboard and achieve your business outcomes.
If this is your first time using the 3DEXPERIENCE platform, check out the video below to understand some of the key aspects that the platform has to offer.
Other Resources for Getting Started on the 3DEXPERIENCE platform
Navigate back to the SOLIDWORKS Learning Resources WIKI and check out the resources available for your SOLIDWORKS learning journey.
Best Practices for using SOLIDWORKS Solutions on Desktop and Cloud. These best practice guides are designed for you to make the most out of your solutions and unlock true value.
3DEXPERIENCE EDU for 3DEXPERIENCE Works
Access the full catalog of role learning paths and modules for the 3DEXPERIENCE Works portfolio of roles.
3DEXPERIENCE Works Learner Library is required to fully access the catalog.
Contact your Reseller Partner for more information.
Feedback
Was this page useful?
Hit the Like Button, or let us know what we can improve in the Comments Section below.
