Expanded Revision Mapping and Easier Client Setup
Revision Control
Benefit from improved synchronization between the SOLIDWORKS PDM revision schemes and 3DEXPERIENCE revision settings, with new options to match source revisioning (if possible) and to increment the target revision on the next source version after the revision is applied.
Map revisions with fewer decisions and use the new help text to see exactly what each option does, including the legacy primary increment behavior.
Simplified Client Setup
Install the client with three prerequisites instead of four. You no longer need to download, install, and configure Apache ActiveMQ, so setup takes fewer steps.
For full prerequisite instructions, see the System Requirements and Prerequisite Installation wiki page in the 3DEXPERIENCE Transition Assistant Partner Support Community.
