3DEXPERIENCE DraftSight Professional, Premium, Mechanical, and Collaborative Designer for DraftSight - R2025x FD03
Collaboration and Cloud Data Management
Batch Print DWG Drawings from the 3DEXPERIENCE Platform
Automate the printing of multiple CAD drawings and sheets in a single job, significantly reducing manual effort, processing time, and errors while ensuring consistent output.
*Only applicable to 3DEXPERIENCE DraftSight Premium, Mechanical, and Collaborative Designer for DraftSight
Mechanical Drawing
Add Weld Symbols
This command creates a welding symbol and attaches it to an object in the drawing area. It ensures clear communication of welding specifications and adherence to industry standards. It enhances the accuracy and quality of technical documentation.
*Only applicable to 3DEXPERIENCE DraftSight Mechanical
Weld Representation
With the new command, you can simplify weld detailing and gain precise control. You can effortlessly create and customize standard-compliant fillet and single-V butt welds (in front or side view) on diverse geometries like ellipses, circles, and lines, ultimately boosting productivity and design clarity.
Add Tolerance Information to Dimensions
Add tolerance information directly to dimensions in drawings to ensure clarity by specifying permissible variations, supporting accurate manufacturing and assembly.
Add Fit Information to Dimensions
Automatically add precise fit information to drawing dimensions by retrieving hole/shaft values from data tables based on the nominal dimension. Save time, reduce errors, maintain standards compliance, and ensure correct part mating and smoother, more accurate assembly.
Construction Lines
Create comprehensive construction lines (rays, xlines, and circular lines) effortlessly with the new command, Use the lines as reference guides to aid in aligning and positioning objects, thereby simplifying complex design tasks, improving accuracy, boosting workflow efficiency, and saving time.
