Our Favorites
- Improved ability to adhere to industry standards for higher accuracy and efficiency.
- Seamless control of file management for increased flexibility in sharing file formats.
Customize table features for greater productivity and flexibility.
Drafting Tool
[NEW] Ability to Change the Unit of Measurement ⭐
Description: Provide the ability to change the unit of measurement in DraftSight.
Benefit: Standardize 2D drafting by seamlessly converting measurements between unit systems.
Applicable to DraftSight Professional, Premium, and Mechanical
[ENHANCED] Block Structure Palette ⭐
Description: Visual representation within the application is required for both top-level blocks and their hierarchical decomposition (nested blocks). Nested blocks, analogous to subroutines in programming, allow for the encapsulation of frequently used geometry within a parent block, promoting modularity and reducing drawing complexity.
Benefit: Empower users to visualize and manage blocks effortlessly with the intuitive block structure palette.
Applicable to DraftSight Premium and Mechanical
[NEW] Flatten Command ⭐
Description: The Flatten command is a powerful tool for converting 3D entities into 2D entities, creating 2D views, and simplifying complex drawings into manageable 2D drawings.
Benefit: Simplify complex entities into 2D drawings with the Flatten command, streamlining your design process and boosting efficiency.
User Interface
[ENHANCED] New Dimension Styles Dialog
Description: Improve the overall user experience and productivity through an interface that closely aligns with features and options found in familiar CAD applications.
Benefit: Enhance the legibility with the improved Dimension Style Manager.
Essential Export/Import Command
[ENHANCED] DGN Export from DraftSight
Description: Allow export of DGN files from DraftSight.
Benefit: Empower collaboration within the architecture, engineering, and construction industry with the DGNexport function by sharing design data, such as graphic elements, georeferencing information, and data related to project construction.
[NEW] Ability to Import STEP Files
Description: Ability to import STEP files within DraftSight.
Benefit: Expand design possibilities and improve workflow efficiency with 3D model STEP import.
Table Customization
[NEW] Table Break Command
Description: Handling large tables that exceed the available drawing space can be cumbersome. The Table Break command lets you split a table into multiple sections and arrange them side-by-side, ensuring optimal layout and readability. This command has been implemented in other CAD applications.
Benefit: Maintain an effective visual of table data with the Table Break command.
[NEW] Auto-Fill Command in Tables
Description: Effortlessly create and populate your tables with the intuitive auto-fill functionality. Simply select a cell and watch as your data expands effortlessly.
Benefit: Reduce repetitive work while editing tables with the cell Auto-Fill command.
Tags:
3DEXPERIENCE platform xApp
User Experience DWG 2d 2d drafting Drawings 2d design
