Tesla’s electromechanical oscillator
Technical Brief
Technical principles and guidelines for 3DEXPERIENCE  reconstruction
Purpose and operating principle
Reconstruct a reciprocating engine coupled to an electrical generator, using the supplied photograph, sectional drawings and patents. Steam or compressed gas drives a piston back and forth. A restoring spring, preferably confined air acting on a plunger, controls the oscillation together with the moving mass. The piston rod drives a moving generator element in a magnetic field, producing an alternating electromotive force. The apparatus converts fluid energy into mechanical oscillation and then electrical output; no crankshaft or flywheel is required for this direct arrangement.
Main components to model
Driving engine: cylinder, piston, rod, inlet and exhaust passages, end covers and seals. Port connections change during the stroke and govern admission and exhaust.
Restoring or timing assembly: air spring cylinder, plunger and, where documented, a jacket or separate timing engine. Do not combine different patent variants without identifying the choice.
Generator: stationary magnetic structure, excitation windings, moving conductor or magnetic element, guides and electrical terminals. In US 511,916 the moving generator element is directly connected to the engine piston.
Structure: base, mounts, fasteners, piping and visible fittings. Use the photograph for exterior proportions and section views to interpret internal parts.
Mechanical and electrical behavior
For a linearized spring and mass model, the natural frequency is f n = [1 / (2 pi)] sqrt(keff / meff ). Air spring stiffness depends on chamber volume, pressure, effective plunger area and thermodynamic behavior. Treat it as approximately linear only for a justified displacement range. The engine supplies energy to offset friction, fluid losses and generator loading; pressure changes can alter stroke amplitude. Constant frequency is a design objective within operating limits, not an unconditional property. Generator voltage follows e = -d lambda / dt, where lambda is flux linkage. Its waveform depends on motion and magnetic geometry. Electrical current creates a reaction force on the moving assembly. US 511,916 discusses circuit adjustment and matching mechanical and electrical periods to limit disturbance of the oscillation; output frequency and power must therefore be assessed with the connected load.
Suggested simulation sequence
First build a parametric assembly with a linear piston degree of freedom, section view and clear port paths. A prescribed sinusoidal stroke can illustrate motion but does not prove self sustained oscillation. For optional dynamic analysis, include gas forces, position dependent port opening, air spring response, moving mass, damping and generator reaction. Couple a magnetic or circuit model to displacement and velocity if electrical output is studied. Report startup conditions, stroke, frequency, load and energy balance.
Sources and reconstruction limits
 US 511,916, Electric Generator (2 January 1894), describes direct engine and generator coupling. US 517,900, Steam Engine (10 April 1894), describes a timing oscillator controlling another engine; it is a related mechanical variant, not the generator patent. The archival photograph and supplied section drawings show complementary configurations whose exact correspondence is unverified. No book excerpt is supplied. Use legible drawing information where possible; otherwise label dimensions, materials, pressure, stroke, magnetic excitation and electrical ratings as assumptions.
Historical Sources
