Tesla's Egg of Columbus
Technical Brief
Rotating magnetic field • SolidWorks reconstruction and optional simulation
Purpose and operating principle
Reconstruct the demonstration apparatus and explain how two phase displaced AC supplies produce rotation in a conducting egg. In the ideal two phase model, perpendicular magnetic components have equal amplitudes and a 90 degree phase difference. Their resultant rotates in the horizontal plane. The field induces eddy currents in the copper egg; their interaction with the applied field produces electromagnetic torque.
Ideal excitation: I A = Im cos(2 pi f t), I B = Im sin(2 pi f t). With corresponding orthogonal field components, B = B0 [cos(2 pi f t) ex + sin(2 pi f t) ey ]. This is a conceptual field model, not a prediction of the actual field distribution.
What to model
Stator: annular ferromagnetic core with two independent coil circuits. Use four coil regions at quarter turns as a simplified topology, with opposite regions paired and winding polarity defined.
Platform: circular support above the stator, with the peripheral guard shown in the 1919 illustration. The article describes a circular wooden board; exact construction remains unverified.
 Egg: axisymmetric copper body. Specify geometry, wall thickness or solid construction, mass and inertia as assumptions. Support and wiring: base, visible fittings and separate phase connections, guided by the supplied images.
Rotation and upright motion
The field drives rotation; it does not directly lift the egg into an upright orientation. Rising involves rigid body dynamics, geometry, frictional contact and energy transfer. Demonstrating this motion requires an appropriate contact model and cannot be inferred from a rotating field animation alone.
Simulation sequence:
1. Build a parametric CAD assembly and check clearances.
 2. Animate an ideal field vector; identify this as an explanatory visualization.
 3. Optional: use a transient electromagnetic solver that supports conductive bodies and motion to estimate eddy currents and torque.
 4. Optional: couple torque to rigid body contact dynamics.
 Declare friction, initial conditions and solver limitations. Confirm available software capabilities before selecting the solver.
Evidence and limits
The 1919 article (pp. 774, 775 and 808) documents the demonstration arrangement and a copper egg. US 381,968 (1 May 1888) supports the rotating field motor principle; it is not a dimensioned patent for this exhibition apparatus. No complete dimensioned drawing is supplied. Frequency, current, turns, dimensions and mass must be recorded as assumptions. The book excerpt and photographs provide context; photograph provenance is not verified in this package.
Historical Sources
Visual References
