Masso G2 Mill XYZ
This post processor is for the Masso G2 controller used with 3-axis milling machines. https://www.masso.com.au/
UPDATED: 05/06/2025
Be sure to glance through the README file first. You will learn how to install and use this post processor. There is also a sample 3dxml file that contains machining operations and toolpaths that were used to test the post processor. Please import this sample 3dxml file into your Common Space for your reference. Here is a short sample of the ISO g-code output from the masso_g2_mill_xyz.dmp post processor:
(0035)
(MASSO G2 MILL XYZ)
(POST VERSION: 050625-1)
(POSTED DATE: 5/6/2025  TIME: 4:35:48 PM)
(T1  D=0.25 CR=0. - 1/4" FLAT 3FL)
(T2  D=0.5 TAPER=135.DEG - 1/2" SPOT DRILL 135)
(T3  D=0.25 TAPER=135.DEG - 1/4" DRILL 135)
(T4  D=0.159 TAPER=135.DEG - #21 DRILL 135 COBALT)
(TOTAL MACHINING TIME = 0:02:01)
G20
(FIN ROUND POCKET)
M01
M05
T1 M06
G17 G40 G49 G54 G80 G90 G94
G00 X-.0007 Y-.1359 S5000 M03
Z1. M08
Z.1
G94 G03 X-.052 Y-.1155 Z.07 I.0099 J.0995 F6
