Tips for Collaborative Industry Innovator (CSV)
Please find below the list of all the tips related to Collaborative Industry Innovator (CSV):
TitleLink to VideoDescriptionDate
ENOVIA Tip | Sharing Review Details with the External Stakeholdershttps://youtu.be/bKyqTxRWc-8
In this short tip about the 3D Markup app, you'll learn how to generate a PDF copy or Images of your review observations to easily share them with any external stakeholders who cannot directly access the markup.21/07/2025
ENOVIA Tip | Add the Search Results view to your Dashboard
https://www.youtube.com/watch?v=p4Mc75IturE
Discover how to include the search results view in your Dashboard05/06/2025
ENOVIA Tip | Save Search Results in Dashboard Tabs
https://youtu.be/jbFwgyUeE38
Discover how to save your search results directly to the dashboard tabs for easy access at any time.27/03/2025
ENOVIA Tip | Search Items that do not Share Common Criteria
https://www.youtube.com/watch?v=nlifWpKXL_I
Learn how to use 'OR' & 'AND' operators while searching in the 3DEXPERIENCE platform to enhance your ability to locate relevant information quickly and accurately. 09/02/25
Did You Know you can clip and section to explore 3D Models without the use of CAD?
https://youtu.be/wFIehOqo2Qg?si=rY5XOQquzPG7W6Mu
Learn how to clip and section 3Models with out the use for CAD on the 3DEXPERIENCE platform using 3D Navigate viewing app.17/12/2024
Did You Know you can quickly access your favorite app using the ‘Open With’ command?
https://youtu.be/KfPJ94WftMI
Learn how to make your favorite app always appear in the list when you use the 'Open With' command in the 3DEXPERIENCE Platform.19/11/2024
Did You Know you can also review the non-CAD objects in the '3D Markup' app?
https://youtu.be/k8EwoJ-iZrg
Learn how to thoroughly review your non-CAD objects, such as documents, in the 3D Markup app and raise concerns (Issues) on-the-fly without leaving the app.31/07/2024
Did you know you can apply a Change Action on an Instance
https://youtu.be/NvswNmz3bU4
In configured structures, a Change can be required on selected instances. In this video, you will learn how to do that in order to trace changes on instances.28/06/2024
Quickly Raising an Issue Without Leaving your Review (3D Markup) app.https://youtu.be/KjrXnWSigfc?si=GdYpB4Qrn3aO6c_BLearn how to quickly raise issue to document your concerns without leaving the review (3D Markup) app.29/05/2024
Duplicate a Change Action
https://youtu.be/sxiviYVWAfU
Description :  Learn how to duplicate an existing Change Action in order to create a new one.12/01/2023
How to Instantly Retrieve Complex Relations?
https://youtu.be/DoCTL9UcYK8?si=-Nfll4GGOs3lD1KY
Learn how to instantly retrieve the required relations using Favorites feature in the Relations app.2/11/2023
Attach Supporting Review Observations on-the-fly while Raising the Issue
https://youtu.be/ruU9d3M4Cmo
Learn how to save time while raising issue by attaching supporting review observations on-the-fly.13/07/2023
How to search for classified content?
https://www.youtube.com/watch?v=PMBEAowt7wA
Learn how to easily build complex queries to search for classified content based on classification attributes.30/05/23
How to visualize desktop files in 3DPlay?
https://youtu.be/w8WP4B0plyM ​​​​​​​
Lean how you can easily visualize certain file formats, in the 3DEXPERIENCE platform, without saving them first in the platform.01/12/2022
Easily Configure Enterprise Item Number that Suits Your Organization’s Policy
https://youtu.be/PBziwFfdIiQ
Learn how your 3DEXPERIENCE Platform Administrator can easily configure the Enterprise item Number (EIN) for quickly referencing and identifying your products.07/10/2022
How to Create the Customized Relations Set to be used in the “Relations” app
https://youtu.be/tHPPGmPskVo
Learn  how you can enhance the usage of the “Relations” app by defining additional relations of your interest, to improve the visibility on your content.23/06/2022
How to Filter on Collaborative Task Widget Using "Context”
https://www.youtube.com/watch?v=S4SfxUeIJ38&list=PLnXLw7ymLRcszo4_KeM0OgVbd4P3FkTp0&index=7
Learn how to filter tasks using “Context” within the widget Collaborative Task.21/03/2022
Transition between 3DS Applications
https://youtu.be/RXA5IgC74N8
Discover tips on how to transit and change the context of one app to another using the 3DCompass22/04/2021
ENOVIA Collaborative Lifecycle widget
https://youtu.be/GBh77XV7Rxo
Learn how to perform lifecycle activities on various types of data using a single universal widget08/02/2022
