Quality Document Author (QUC) - R2024x FD02
(Tip: You can use the Table of Content on the right side, to view the list of all enhancements)
Manage Questionnaires in 'Controlled Document Management’ widget
Why
Improve Controlled Documents review and approval process by using questionnaires
How
•We now support Questionnaires in the 'Controlled Document Management’ widget
•Questionnaire provides the framework to automatically identify desired approvers,
templates and classifications for Controlled Documents based on user responses
to each question.
•Two type of questionnaires are supported:
•Creation: Used when creating a new Controlled Document from scratch.
•Approval: Used when creating a new Controlled Document from
Controlled Document Templates that have questionnaires defined.
Notes:
1.In this release, using the 'Controlled Document Management’ widget, you can only create a new Controlled Document based on Approval questionnaire.
2.You can add the following as related data to questions: Controlled document template, a person, route template, or library class.
Controlled Document Support for Enterprise IP Schema Specialization On Cloud
Why
Improve cloud administration by customizing the data model of controlled documents
How
You can now customize a controlled document's data model, create new subtypes and attributes in ‘Enterprise IP Schema Specialization’ on cloud.
Manage Document Rendition Templates in 'Controlled Document Management’ widget
Why
Enhance PDF rendering by defining Rendition Document Templates
How
•A new Category ‘ Rendition Templates’ was added to the ‘Controlled Document Management’ Home Page,
allowing you to create and manage Rendition Document Templates (RDTs).
•Rendition Document Templates are used to define cover pages or a first page overlay
(such as an approval stamp) for each file that is attached to the Controlled Document when rendering the PDF.
•You can create Rendition Template for each ‘File Category’.
•Using the ‘File Category’ set on the file level as well as on the Rendition Template,
the system knows which RDT to use for each file, when rendering the PDF.
Collaborative Spaces Configuration Center Settings for Controlled Documents
Why
Enhance Controlled Documents process through some admin settings
How
•The ‘Quality Document Control’ category ‘Collaborative Spaces Configuration Center’  is now renamed to ‘Controlled Document Management’.
•Only applicable settings are displayed for On Premise and On Cloud Environments
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
