New enhancements in this release for this role:
(Tip: You can use the Table of Content , on the right side, to view the list of all enhancements)
Schedule Critical Path |
Why Stay aligned with Project Management standards by implementing ‘Critical Path’ Method |
How You can now display the Critical Path in the Schedule view. To display the Critical Path, use the ‘Display Preferences’ menu and select one of the following options:
Note that Critical Path is available for Enterprise Projects only.
Project Planning Welcome Panel Updates |
Why Save time by accessing your favorites and recent projects from the Project Planning Welcome Panel |
How ‘My Projects’ and ‘All Projects’ views are removed from the ‘Project Planning’ Welcome Panel, and being replaced by two new views: ‘Open Projects’ - allows you to search for a project and open it. ‘Recent Projects’ - displays your favorite projects, along with up to 20 recent projects.
Manage Favorite Projects |
Why Save time by accessing your favorites projects directly from the Project Planning Welcome Panel |
How You can now add projects to Favorites or remove projects from Favorites. To do that use either:
All Favorites Projects are listed in the ‘Recent Projects’ view in ‘Project Planning’ Welcome Panel, and have the Favorite Icon
Show Planned Dates in Properties Even When Actuals Are Set |
Why Improve productivity by always showing the Planned dates of a Task |
How
Bookmarks as Repository for File Upload |
Why Facilitate bookmark process by integrating bookmark in Project Planning app |
How You can now specify a Bookmark Root or a Bookmark that will be the target for any uploaded document. To support that a new field, called ‘Bookmark folder for File Upload’ is available in the Project’s property panel. |
Restrict Assignees Access on Tasks |
Why Minimize potential misuse by controlling assignees access. |
How New setting, ‘Restrict Assignee Access’ is now available on project level.
Note that 'Restrict Assignee Access' is available for Enterprise Projects only. |
Schedule Project at Project Start Date or Current Date |
Why Improve project planning by scheduling the project at Project Start Date. |
How New setting, ‘Scheduling From Strategy’ is now available on project level. The setting is used to define the scheduling Start Date, and can have one of the following values:
Create Commands in shortcut Menu for Content Creation |
Why Enhance productivity through quick creation of project elements using the shortcut menu. |
How In Schedule view, create commands are available in the shortcut menus of Tasks and Projects:
New Tasks Table View |
Why Improve navigation and focus on tasks through a new ‘Table View’. |
How New view named ‘Table view’ is now available in the Tasks tab under ‘Switch view’ menu. |
Tooltips Show Modified Information |
Why Improve productivity with quick access to more information in the tooltip. |
How You can now see the modified description of a task or a milestone, as part of the popup tooltip when comparing schedule with baseline. |
🎬 To discover more about these enhancements, watch the video below:
Note that the video has a voice over that can help you better understand the content
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
