(Tip: You can use the Table of Contenton the right side, to view the list of all enhancements)
Export Projects as a Group |
Why Improve time and effort required to export projects by grouping related projects and export them together |
How •You can now export multiple projects to a zip file, by selecting multiple projects and use the ‘Export’ command available in the ‘Actions’ menu. •This is available for : •Selected program -> Projects page •Project section -> Projects page
•The zip file which includes all projects will be downloaded and also sent to the log in user via email. Note: Subprojects are not exported. |
Add Project Column for Flexible Links view |
Why Improve efficiency by providing more information about the Flexible Links in the Flexible Links view, such as the governed project |
How •The ‘Passive Tasks’ view is renamed to ‘Flexible Links’ •The “Add Passive Project/Task” command is renamed to “Add Flexible Links” •A new column, ‘Flexible Links Project’, is introduced in the ‘Flexible Links’ view, displaying the hyperlinked project that governs the flexible links tasks, and available in both applications: •Project Management application •Project Gantt widget
Add external URL as attachment in Risk Management App |
Why Enrich Risks and Opportunities information by supporting external links as attachments |
How •A new command, ‘Add Link’, is introduced for Risks and Opportunities in their respective ‘Information Panel’-> ‘Related Content’ tab, which allows you to add external URL as attachment. •This type of attachment is marked as favorites with a blue star icon to distinguish it from standard attachments. •Using the Attachments Menu, you can open the link by selecting the ‘Go To Link’ command
Link Bookmark Documents on Project Template Revision |
Why Improve reuse by linking instead of copying documents, when revising a project template |
How •A new setting ‘Link, rather than copy, documents when revising the project template‘ is now introduced and available in the ‘Collaborative Spaces Configuration Center‘ widget under Project Management -> Project Template Behaviors section. •It allows you to connect existing bookmark documents from previous project template to a newly revised one. •By default, the setting is unchecked, which means that when revising a project template, the documents are copied and not linked. |
Project Gantt User Interface Improvements |
Why Enhance productivity with improved user experience in the Project Gantt application |
How •The ‘Repeat’ checkbox is now available in Schedule tab when creating new project items to keep dialog open after creation. •The Schedule view is automatically expanded to the same structure as it was before. |
Add Symbols for Milestones and Gates in Project Gantt |
Why Identify major milestones and gates quicker by applying a distinctive icon for selected milestone or gate. |
How •You can apply an icon for a selected milestone or gate in the Gantt view. •This is available in the Gantt view in the following applications: •Project Management •Project Gantt
Sharing Project Template with other Members |
Why Standardize project creation and capitalize project content across the organization by sharing project templates with other members |
How •A new Category ‘Sharing’ is added to Project Template, that allows you to share the Project Template with: •Individual Members •Use Groups •Collaborative Space Members •The users added to the template, have Reader access to the template. |
Restrict Assignees Access on Tasks in Project Management App |
Why Minimize potential misuse by controlling assignees access. |
How •New setting, ‘Restrict Assignee Access’ is now available on project level in Project Preferences in both applications: •Project Management •Project Gantt
•No is the default value set for newly created projects. •Yes The task assignee has limited modification access, and can edit only the following fields: •Maturity State •Percent Complete •Deliverables •Attachments •Estimated End Date/Start Date •Estimated Duration |
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
