New enhancements in this release for this role:
(Tip: You can use the Table of Content on the right side, to view the list of all enhancements)
Derived Output Generation |
Why Improve design collaboration with external stakeholders |
How •You can now generate Derived Outputs from the “Derived Output” tab •After generation, you can also download these files locally Note: You need the proper conversion role to get your desired format. For example: to generate the STEP format you need Conversion Data Integrator for STEP Multidiscipline (STS) |
Export Derived Output (“Export As”) |
Why Improve design and manufacturing collaboration |
How You can now export generated derived outputs and other content of the complete product structure, according to the following selection: . Export Part As: Enables you to select which CAD file to be exported (native format) - Secondary Format: Enables you to export the derived outputs (in case they were generated..) - Export Drawing (native: PDF) During the process, a job is created. The notification panel informs the user when the job is finished. |
The following roles are a prerequisite: -Enterprise IP Integration Large Pack (XXK-OC) -Enterprise IP Integration Manager (XXH-OC) -These roles enable the STEPAP242 export -3D Product Architect (PAU-OC) - This role enables the xCAD export (SOLIDWORKS, CATIA v5, Inventor) |
This enhancement is available only on Cloud |
🎬 To discover more about these enhancements, watch the video below:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
