New enhancements in this release for this role:
(Tip: You can use the Table of Content , on the right side, to view the list of all enhancements)
Customize Attributes displayed in the ID Card |
Why |
How - Adding/removing attributes - Defining the attribute order This is available through a new command in the contextual menu of the ID Card. |
Specification Document Column in the widget |
Why |
How When you click on this icon, the property panel is launched, and the "Specification" tab is selected to enable you to view these documents. |
Grouping from the Tagger |
Why To enable you to focus on products in the Engineering Definition, which are relevant to your needs (Such as in the case of products that belong to a specific discipline) |
How You can group the products in the Engineering Definition based on a tag from the list of tags in the 6Wtags. This will group all the products under this selected tag, in the Engineering Definition. The other products will be grouped under a "group" called "Others”. |
Enterprise Item Number Enhancements |
Why |
How There are two new administrative options in the Collaborative Spaces Configuration Center, that enable you to: - Manually set the Enterprise Item Number (EIN) - Generate an EIN based on:
(*) Business logic has higher precedence over the Formula. The Formula has a higher precedence over the user input mechanism |
New Menu that unifies all Product Structure views |
Why |
How All view options of the Product Structure are now gathered in a single menu in the toolbar: |
🎬 To discover more about this enhancement, watch the video below:
Note that the video has a voice over that can help you better understand the content
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
