Enterprise IP Integration Manager (XXH) - R2023x FD02
New enhancements in this release for this role:
(Tip: You can use the Table of Content   on the right side, to view the list of all enhancements)
Engineering Exchange Service: Detailed Import Report
Why
Easily find the status of your import by referring to the detailed import report
How
- You can now download a full report for the import of data through the Engineering Exchange service. The import report can be downloaded from the download link in the Results or the Family tab.
- The downloaded zip file contains short report (Main.json) and other detailed report for every package that as been delivered.
Engineering Exchange Service: Importing stand-alone Documents
Why
Improve your collaboration with suppliers thanks to the support of importing stand-alone Documents with Exchange Service
How
- You can now use the Engineering Exchange service to Import stand-alone documents (STEP AP242 XML Format) from external system as 3DEXPERIENCE Document.
Note:
- Events for document creation are not generated when document is created using import.
- The enhancement to support import of standalone documents will only be available in the iPaas mode.
Engineering Exchange Service: Importing Power’By SOLIDWORKS Data (SDLASM)
Why
Improve your collaboration with suppliers thanks to the support of importing Power’By SOLIDWORKS Data (SDLASM)
with Exchange Service.
How
- You can now use the Engineering Exchange service to Import of SolidWorks SLDASM data exported from external system into 3DEXPERIENCE Platform as Unified Product Structure data model
- Links between SDLASM and other files (SLDPRT) is supported.
- Following operations are also supported:
  • CREATE: This option can be used when the data is new and to be created in 3DEXPERIENCE
  • DELETE: This option can be used when the data has been deleted in external system and should be deleted to in 3DEXPERIENCE
  • MODIFY: This option can be used when the data has been modified in external system and should be updated in 3DEXPERIENCE
  • NOMODIF: This option can be used when the data has not changed in external system and no operation is expected to be reflected in 3DEXPERIENCE
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
