Depending on which offers are chosen, there are two ways to access the learning experience:
3DEXPERIENCE Edu Space
3DEXPERIENCE Edu Space is the Dassault Systèmes eLearning portal, accessible at the following URL: https://eduspace.3ds.com. Since it is available online, learners can log in from anywhere, at any time. Learners can access a list of training materials tailored to their roles, profiles, and business needs.
Edu Space Login
Here are three login options:
| 1. | Sign in using a registration voucher | Check out the video for instructions on signing in with a registration voucher. |
| 2. | Log in using your organization's portal | |
| 3. | Login in using your 3DEXPERIENCE ID |
📚HOME Tab
The Home panel is divided into three zones, allowing you to access your Recent Learnings, Assignments, and Favorites:
📙CATALOG Tab
The Catalog displays learning paths, learning modules, and certifications available for your role(s) and profile. Learning paths include several learning modules and may also have certifications.
Two viewing options are available for the catalog.
| All Contents: A collection of learning paths, learning modules and certifications. You can use the filter to find the right content. |
| Library Based: Consolidated learnings based on your libraries |
3DLearn
3DLearn is an application directly available from the 3DEXPERIENCE. It is only available on cloud solution.
Learn - Anytime, Anywhere by logging onto the 3DEXPERIENCE platform and using the 3DLearn widget.
📚HOME Tab
The home panel is divided into three zones, allowing you to access your Recent Learnings, Assignments, and Favorites:
📙CATALOG Tab
The catalog displays the library you have access. The learning paths, learning modules, and certifications are available in the libraries.
| Available Learnings: Consolidated learnings based on your libraries you have access to. |
Navigation
1. Display the learning path/learning module
Click the title to display the learning path or the learning module content and its details.
Top Bar: Displays details of the learning path/learning module, including progression, duration, and release information
Contents Tab: Shows the lessons that make up the course, along with their duration and your progress and status for each
Details Tab: Provides the course description, objectives, duration, available releases, audience, level, and available languages
2. Choose a language in a learning path / learning module
- To run a learning path / learning module in a language other than English, select your preferred language from the drop-down menu.
- You can also set a default language for your courses. To do this, navigate to the My Settings menu or refer to the User Settings section.
- If only one language is available, it indicates that the learning path / learning module is offered exclusively in that language.
3. Choose a release in a learning path / learning module
- When searching for a learning module or learning path, a notification will appear on the card indicating the number of additional releases available if multiple versions exist (e.g., "+2 more" following the latest version).
- To run a learning path/learning module in a release other than the latest, select the desired release from the drop-down menu.
- If only one release is available, it means the learning path / learning module only exists in that release.
Support and Report Issue on Edu Space
If you have access issues to Edu Space, please contact your platform ADMIN or your partner.
You can also use the 3DSupport App (tutorials are available here).
If you are connected to Edu Space and find an issue, you can also report it directly from the eLearning portal.
If needed a learner guide is also available directly from Edu Space:
