New enhancements in this release for this role:
(Tip: You can use the Table of Content , on the right side, to view the list of all enhancements)
Exclude Selected Nodes Before Export(Conversion Data Integrator for STEP Multidiscipline) |
Why Enhanced control over exported content through selected exclusion of nodes in the specification tree |
How You can now select a node of the structure to export and a dialog lets the user decide to exclude or export the node. A B.I. Essentials box appears when the user starts the export of the product The status of his choice is visible in the tree and in the B.I. Essentials box. |
Extended Support for Newer CAD Releases(Conversion Data Integrator for AutoCAD) (Conversion Data Integrator for Creo Parametric and Pro/ENGINEER) (Conversion Data Integrator for Inventor) (Conversion Data Integrator for NX) |
Why |
How |
| Role | Supported Versions |
| Conversions Data Integrator for AutoCAD (FOC) | AutoCAD 3D 2023 |
| Conversions Data Integrator for Creo (FOP) | Creo 9 |
| Conversions Data Integrator for Inventor (FOI) | Inventor 2023 |
| Conversions Data Integrator for NX (FON) | NX 2206 |
Reposition Data in the CAD Design Space(Conversion Data Integrator for COLLADA) (Conversion Data Integrator for FBX) (Conversion Data Integrator for OBJ) |
Why |
How Data can now be moved closer to the origin within the existing design range of the system to reduce errors on import The coordinates of the dataset is shifted to fall within the design space of the CAD system The shift is applied to all the geometry to maintain the integrity of the import |
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
