Collaborative Industry Innovator (CSV) - R2024x FD03
(Tip: You can use the Table of Content on the right side, to view the list of all enhancements)
Project Gantt User Interface Improvements
Why
Enhance productivity with improved user experience in the Project Gantt application
How
  • the "Repeat" checkbox is available in Schedule tab when creating new project items to keep dialog open after creation
  • The Schedule view is automatically expanded to the same structure as it was before.
    This applies when you return to the Schedule View from a different view or change the filter
Support External link as Attachments
Why
Enrich tasks information by supporting external links as attachments
How
• A new command, ‘New Link’, is now available in the ‘Information Panel’ of the task,  which allows you to add external URL as attachment.
• This type of attachment is marked with a URL icon to distinguish it from standard attachments.
• Using the drop down menu, you can open the link by selecting the ‘Open Link’ command.
Data Grid with filtering
Why
Improve decision making through an improved data grid view
How
You can now configure the Revision Explorer view in ‘Collaborative Lifecycle’ app with the following capabilities:
• Reorder the columns
• Resize the columns
• Filter the content
Issue Management: Supporting 3DSwym and Project Planning Objects in Issue contents
Why
Increased traceability by supporting additional objects in the issue contents section
How
  • You can now attach the following objects in the Issue Contents (Affected Items, Context, Resolved By) section:
    • 3DSwym: Posts, Media, Idea, Questions, Wiki
    • Project Planning: Project, Task
    • Design with CATIA Magic: System Model
▶️ Demo Video
Compare App: Customized Comparison Profile
Why
Increased flexibility and improved speed while comparing Engineering Items using the customized comparison profile
How
  • In the Compare app settings, you can now create a new customized comparison profile by duplicating default profile.
  • The customized compare profile allows you to define:
    • Custom Status: To compare two or more attributes of the Engineering Items together and display comparison results by color of your choice.
    • Additional Status: To compare more attributes of the Engineering Items
Managing Units in the Properties Tab
Why
Increased flexibility while updating value of the dimension attributes
How
  • Along with the value, you can now also change the Unit of the dimension attribute from the Properties tab.
  • If the preferred unit is defined for the attribute, it cannot be changed from the properties tab. The given value is converted to display in the preferred unit.
 🎬 To discover more about these enhancements, watch the video below:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
