Collaborative Industry Innovator (CSV) - R2024x FD02
(Tip: You can use the Table of Content on the right side, to view the list of all enhancements)
History Tab in Information Panel
Why
Improve regulatory compliance by capturing and listing all user actions performed on an object
How
•New tab ‘History’ is added to the Information panel in the ‘Collaborative Lifecycle’ application.
•The ‘History’ tab displays history details of a selected object ,including:
•Modified On
•Modified By
•The Action
•The Maturity State
•The Details.
The details column includes a link to the respective object
which can be opened in other applications.
For example, in case of adding a specification to a part,
you can navigate to the specification from the Details column.
Classification Tab in Information Panel
Why
Facilitate classification process using a direct classification information from the Information Panel
How
•A new tab ‘Classification’ is added to the Information panel in the following applications:
•IP Classify & Reuse
•Bookmark Editor
•IP Export Control
•Using the new Classification tab, you can perform the following operations on a single selected object:
•View the classes and bookmarks the object is associated with
•Classify / Declassify
•Add to bookmark / Remove from bookmark
•View and update classification attributes
Preview Multi-File Document
Why
Improve productivity through a new navigation panel in “Preview”..
How
•A new Navigation Panel is introduced in Preview, that lists all Document Files.
•Using the Navigation Panel, you can perform various operations on the document files:
•Sort the list of files based on different criteria
•Search for file to preview
•Perform file operations, such as Edit, Lock, Update, Copy Link and Download.
Access Bookmark Editor and 3DSpace apps from Content Panel
Why
Enhanced productivity through a direct access to Bookmark Editor and 3DSpace apps from the Dashboard
How
  • You can now access the Bookmark Editor and 3DSpace apps from the Content Panel in the 3DDashboard.
  • Also, you can expand this panel to full-screen mode for effective navigation through your content.
Bookmark a Post
Why
Quick access to important information shared in community
How
  • You can now add posts as content in bookmarks using following methods:
    • Use the Add Existing content option
    • Search for the required post and drag-and-drop it from search results to bookmark
  • This allows you to organize posts along with other information related to a specific project or a product in one bookmark
  • You can also add a URL Link in the bookmark to redirect stakeholders to a specific object or external page
Relations: Opening Paths and Objects in the native app within 3DEXPERIENCE CATIA
Why
Improved efficiency thanks to the ability to quickly open objects from relations app into native app in 3DEXPERIENCE CATIA
How
  • You can now use the Open With option in the context menu of the path available in the Find Paths panel of the Relations app.
  • The Open With option shows the compatible native apps in which you can open the structure. You can also select the required app from the Compass.
Notes:
  • If the “Include All the Relations In the Structure” checkbox is selected, it opens the selected objects along with their tree structure in the native app.
  • If the “Include Only the Relations In this Session” checkbox is selected, it opens each selected object as root in the native app.
Routes Management: Restarting and Revising a Route
Why
Improved traceability with the ability to revise the route
How
  • When you restart the Route, a new revision of the route is automatically created. In this case, the previous route is marked as Completed and no operations can be performed on that route.
  • If a current route (Before revision) contains an incomplete task, it is not completed but carried-forward to the revised route.
  • The new "Revision" column is added in the Summary page of the app that displays the latest revision of the route. Along with this, the route ID card also shows the revision of the route
  • You can use the new Revise option from the Summary Page or the ID Card of the route. It displays existing revisions and lets you revise the route if required
🎬 To discover more about these enhancements, watch the video below:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
