New enhancements in this release for this role:
(Tip: You can use the Table of Content , on the right side, to view the list of all enhancements)
⚡ Link Multiple Files to a Document |
Why Streamline Document Management process by accessing and working separately on each file of a document in a single view |
How New tab, named ‘Files’, was introduced in Document Management application in the Information panel of a selected document. The Files tab allows you to:
New column, named ‘Files’ was added to the document content view:
The ‘Lock Status’ column has been enhanced to display lock information of all files
Approval Status column within Bookmark Editor widget |
Why Make informed decisions on objects, through the new Approval Status column |
How You can now add ‘Approval Status’ column to the content view in Bookmark Editor application. The ‘Approval Status’ column allows you to view the approval status of an object based on its associated route/s. By using the object context menu, you can now:
Note: The ‘Approval Status’ column is not shown by default. You can enable it using the Custom Views panel. |
Support Web Edition of MS Office Documents (Bookmark Editor) |
Why Speed up productivity by editing office documents directly in the web browser |
How You can now open, edit, and save office documents in the web browser also from the Bookmark Editor widget Note: To enable this enhancement, the following setting should be enabled: “Enable Office Document Editor’, (available in the ‘Platform Management’ dashboard, under the ‘Content’ tab in the ‘Office Document Editor Control Center’ section )
| This capability is available on cloud only |
Creation Panel to Create a Bookmark |
Why Reduce errors and save time through a new Bookmark creation panel |
How You can now set Bookmark information during the creation of a Bookmark:
Edit and Update Document from Search Within |
Why Save time by editing and updating a document directly from the search within dialog in Bookmark Editor app |
How
⚡Duplication of Bookmark with Suffix and Prefix |
Why Improved Bookmark duplication process by adding prefix and/or suffix to duplicated bookmark |
How You can now set Prefix and/or Suffix when duplicating Bookmarks
Ability to Push Subscription on Bookmarks |
Why Improve awareness through notifications |
How You can now push subscription to others in Bookmark Editor app This is done using two new commands that were added to the Subscription menu toolbar:
Support of Subscriptions & 3DNotifications for Classification |
Why Improve awareness on events of classification through notifications |
How You can now subscribe and push subscription to a general class for specific events, such as:
The Subscription menu is available in the toolbar of both applications:
⚡Report an Issue Using Existing Issue Template (from 3D Markup) |
Why Save time by using the predefined issue template while reporting on issues in the 3D Markup app |
How
Cross-Highlighting Between Issue Management and Other Apps |
Why Easily find the required issue by cross-highlighting it from other apps |
How
⚡Route Management: Setting “Blocking Maturity” for Route Content |
Why Seamlessly control the maturity state of the Physical Product and other types of objects in the route content until route completion |
How You can now block the maturity state promotion of the following object types added in the route content:
⚡Route Management: Setting “Target Maturity” for Route Content |
Why Improve your approval process by the ability to set target maturity state of the route content |
How
🎬 To discover more about these enhancements, watch the video below:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
