New enhancements in this release for this role:
(Tip: You can use the Table of Content , on the right side, to view the list of all enhancements)
Issue Management: Filter by Object |
Why Easily find the list of required issues by ability to filter issues based on objects |
How - With this enhancement, you can now filter the issue list by objects to easily find required set of issues related to specific content. - The new "Filter by Object" option is provided in the filter menu which opens the search field where you can enter the name of the object to filter. - From the settings, you can select any of the following checkbox to decide the required criteria for filtering:
Support Route Information in Document Management App |
Why Make informed decisions on documents, through the new Approval Status column |
How You can now add ‘Approval Status’ column to the documents data grid in 'Document Management' application. The ‘Approval Status’ column allows you to view the approval status of a document based on the associated approval route/s. By using the document context menu you can now:
Note: The ‘Approval Status’ column is not shown by default. You can enable it in the 'Custom Views' panel.
3DXML Support for Document Downward |
Why Improve backward data sharing compatibility, by including document objects in 3DXML |
How Backward compatibility on document objects is now supported, allowing you to share data corresponding to document objects from R2023x level to:
The following data flow illustrates the mechanism:
Edition of Classification Attributes in Data Grid View |
Why Boost productivity by editing classification attributes values in data grid view |
How You can now set and edit the Classification Attributes values, directly in the data grid view in ‘IP Classify & Reuse’ app
Widget Link - App Synchronization |
Why Keep consistency through widgets content synchronization |
How You can now synchronize content and filters between linked widgets To link between widgets, use the ‘Link with widgets’ command available in the widget drop down menu. The supported widgets:
Note: Content synchronization is not supported between two 3D Viewer widgets.
Support Task Multi-Selection in Collaborative Tasks |
Why Improve productivity through multi-selection of tasks |
How You can now drag and drop multiple tasks across columns or to another widget in ‘Collaborative Tasks’ app. To multi-select tasks, you first need to enable the multi-select mode, using one of the following methods:
When the multi-select mode is enabled, the tasks icons turn to gray check marks When the task is selected the check mark turn blue |
3D Navigate: Define a Start-up View |
Why Improve collaboration by easily sharing the required viewpoint of the product with any stakeholder |
How - You can now define a startup view in the 3D Navigate app to automatically load an object with a specific viewpoint when you open the app afterwards. - The new “Set as Startup View” option is provided in the bottom-right corner of the widget. You can position the product to the required viewpoint and select this icon to fix the viewpoint. - You can define the start-up view in the 3D Navigate app and share the dashboard with other stakeholders. When they open the dashboard, the same startup view is also displayed to them. Note: You cannot modify an existing startup view, but you can remove it and create a new startup view. |
Bookmark Editor: Creating Bookmark Shortcuts |
Why Quick navigation to required bookmark by ability to create shortcuts of the bookmark |
How - With this enhancement, you can now create shortcut of the bookmark in any other bookmark. - To do that, you can copy the bookmark and go to the target bookmark where you want to create a shortcut. - Upon selecting the Paste command from the context menu, a new dialog box is displayed. You can select the “Paste as a Shortcut” option which creates a shortcut of the copied bookmark in the target bookmark. - When you double click on this shortcut, you are redirected to the original bookmark. Notes:
Relations: Enhancements in the Find Paths Panel |
Why Improve productivity and save time while finding paths between two relations |
How - With this enhancement, the Find Paths panel has been improved to show you following two options when you select the start and stop objects:
Change Action: Support User Groups as assignees and informed user |
Why Improve accuracy and save time by utilizing user groups to assign change action |
How - You can now add a User Group as an Assignee or Informed Users of your change action. - User Groups added as the Assignee or Informed Users are shown with user group thumbnail and name of the user group. |
Collaborative Space Configuration Center: Revision Format for Document |
Why Improve consistency by aligning the revision format of the document with other data types (Engineering Definition, other) |
How - A new option is provided that lets your administrators independently select the "Primary" or "Primary and Secondary" Revision format for Documents in the Collaborative Space Configuration Center app. - When the "Primary and Secondary" Revision format for Documents is selected, the Primary ID is incremented when the document released document is revised. Else, the secondary ID is incremented. |
🎬 To discover more about these enhancements, watch the video below:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
