Collaborative Designer for Creo Parametric (UDO) - R2023x GA
New enhancements in this release for these roles:
(Tip: You can use the Table of Content   , on the right side, to view the list of all enhancements)
Note:
All of the enhancements covered in this release are delivered through the introduction of "MySession" - an immersive user experience that allows Creo Parametric users to take part in a collaborative product development processes with a streamlined look and feel.
Change Security Context
Why
Easily change your credentials at anytime during the session
How
  • You now have access to multiple security context like role, organization and collaborative space from within the Creo session.
  • Changing security context no longer requires you to login and logout of the CAD session.
  • A new command prompt will provide the prompt for viewing or changing existing credentials
    Change Ownership of CAD Components
    Why
    Save time managing Creo components with the ability to change ownership from within your CAD session
    How
    • Change Ownership of a components in the CAD system from the MySession application.
    Change Login Credentials
    Why
    Save time managing Creo components with the ability to change the Collaborative Space and Organization from within your CAD session
    How
    • Change the Collaborative Space and the Organization of components in the CAD system from the MySession application.
    Change MySession Settings
    Why
    Enhanced control of Session settings through control using the MySession window
    How
    • Users will be able to change following options from this dialog:
    • Save Options
      • Delete Local files
      • Retain Lock
      • Use PMI for CGR
    • Open Options
      • Lock
      • Load files
      • Download Filter
      • Related Drawings
    Open Design from 3D Search
    Why
    Quickly locate and open your design data with 3D Search from within the Creo environment
    How
    • Open CAD design data from the MySession application through a search function into a new CAD application session, or into an existing session
    Expand and Collapse Product Tree
    Why
    Improve clarity of the product structure changing the content shown in the MySession product tree
    How
    • You can now alter the number of visible levels of the product structure at anytime during the Creo session using the MySession window
    Customize Columns and Attribute Display
    Why
    Personalize the product details shown in the MySession product tree
    How
    • Right-click any component in the MySession window to display the available attributes
    • Re-arrange the order of columns by dragging and dropping them left to right
    Work Under Change
    Why
    Work under an existing Change Action to automatically track changes to the design
    How
    • You can now choose a Change Action and associate it with the components in the current  Creo session
    • Add, remove, activate and deactivate change actions in the current session with the MySession window
    Access Rights to CAD Components
    Why
    Lock and unlock design components during the design session to ensure exclusive control over changes
    How
    • You can now lock and unlock the design components from within the current Creo session
    • After a lock or unlock operation, the MySession window will refresh to show the correct status
    Access Component Relations
    Why
    Quickly expose relationships in the structure
    How
    • Select any component in the MySession window to access the relationships between the design components using the Relations  icon in the MySession > Tools menu
    Manage Component Attributes
    Why
    View and update the attributes directly from your design session
    How
    • Access the attributes of any component in the current Creo session by right-click of the component in the MySession window
    • Based on your rights during the session and the lifecycle state of the component, you can edit and update the attributes of the component
    Replace Revisions
    Why
    Replace the component with a different revision to better understand changes
    How
    • Enable user to perform ‘Replace by Revision’ for a selected design in the  MySession window of the active Creo session
    • This function will download the selected components and open it in the CAD session
    Set Engineering Item Number
    Why
    Assign Engineering Items Numbers to components directly from within the Creo session
    How
    • During save of the CAD design, you can now assign an Enterprise Item Number from the MySession window
    • The Enterprise Item Number can be edited and re-assigned during save even if it is already assigned
    Save to Platform
    Why
    Quickly save your design to the platform at any point in the design effort
    How
    • Save designs, structures and drawings from the native Creo application using Save active option in the MySession window
    Change Maturity of Design Data
    Why
    Change the state of any component in the structure
    How
    • You can now change ‘Maturity’ of selected design within the active session from the MySession window
    Access Platform Applications
    Why
    Save time launching supported platform applications
    How
    • Open supported applications on the 3DEXPERIENCE platform directly from the Creo session using the MySession window
    • Supported applications will open directly in the MySession panel or in a separate window depending on the application
    • You can switch between multiple application opened in the MySession window using a pull-down list of applications
    🎬To discover more about this enhancement, watch the video below:
    If you have any question or comments on these highlights, please share them with us below. Thanks!
