3DSwymer (IFW) - R2023x FD01
New enhancements in this release for this role:
(Tip: You can use the Table of Content   , on the right side, to view the list of all enhancements)
 3DPassport
Delegated Authentication
Why
Keep consistency between all your accounts by easily mapping your 3DEXPERIENCE ID to your local authentication system.
How
User authentication is delegated to the customer's identity provider. It is important to note that the very first time the user logs in, they must associate a 3DEXPERIENCE ID (new or existing - highly recommended for existing platforms).
Note that until now, this feature was only available for on-premise and dedicated/private cloud. Now you are able to implement it in the public cloud as well.
 3DDashboard
PartSupply accessible via Topbar
Why
Save time by accessing PartSupply directly from the Topbar
How
PartSupply tool is now accessible via the Topbar.
You can simply click on the 3DDrive Icon> Use the Arrow next to 3DDrive> Select PartSupply
 3DDrive (Cloud only)
External drives activation by tenant
Why
Gain more control over the drivers you want to activate or deactivate
How
 As a platform administrator, you are now able to deactivate or activate any of the external drives for your company.
From Platform Management Dashboard, access the "Content" tab, then in "Drives Control Center" widget, select "Manage Settings" section.
 3DPlay
 "Share as comment" option available for 3D Data
Why
Save time by opening the previous review alongside your 3DModel, in the comment section
How
You can now use the option "share as Comment" to save your annotations on 3D Model data, displayed in 3DPlay.
This option allows you to keep a track of these annotations in the comment panel (next to the property panel of 3DPlay) of your 3D Model. Note that the reference image created in the comment, can be re-opened with all its content (annotation, view point, measure & section) in 3DPlay.
Watch this video that illustrates this new feature:
 Keyboard Shortcuts available for PDF file
Why
Save time by using shortcuts while navigating on 3DPlay content
How
You can use the keyboard shortcuts for PDF file opened in 3DPlay.
 This behavior is activated for PDF content opened directly in a 3DPlay widget and not for embedded 3DPlay instances inside 3DDrive, 3DSwym, etc.
3DSearch
Boolean operators available in 6wTags
Why
Save time by retrieving the relevant content quickly using the boolean operators
How
From now, you can apply operators in the 6wTags panel. This way you are able to apply the right sets of filter to retrieve the relevant content easily.
Note: The administrator of the platform should first activate the option in the Platform Management Dashboard.
 3DWhiteboard (Cloud only)
Lock object in the 3DWhiteboard
Why
Protect your 3DWhiteboard from undesired modifications by locking it
How
You now have the possibility to lock objects in the whiteboard using the "lock" icon, ​​​​​​​to enable you to work on adjacent objects without impacting the locked ones. ​​​​​​​
  3DWhiteboard 3DSketch (Cloud only)
Publish Whiteboard/Sketch into a conversation from their widgets
Why
Reveal your Whiteboard/Sketch creations to a wider audience through conversations
How
You now have the possibility to create a 3DSketch/3DWhiteboard in a conversation through the widget.
When you click on "My Content" section, you can select from the list of conversations, the one to be used to share your creation content.
 3DStory (Cloud only)
General Enhancements
Why
Improve your productivity through various enhancements in this app.
How
Click in the story below to discover them:
If you have any question or comments on these highlights, please share them with us below. 👇
Thanks!
