List of fixed SPRs
| SPR | Brief Description of issue(s) fixed |
| 1254252 | Import/Export Smartleaders outside viewport being trimmed. |
| 1251553 | Blocks Dynamic blocks created in AutoCAD not behaving correctly when opened in DraftSight. |
| 1250766 | Toolbox DraftSight Mechanical: Help button not working for feature control frame. |
| 1250464 | General Double mouse pointer / lag and pan(hand) symbol being visible after drag drop opening file. |
| 1249892 | Layers Edit layer filter help not working. |
| 1249281 | General Autostack dialogue does not appear when used with a nonnumeric character. |
| 1248909 | Blocks Warning dialogue box appears blank in Dark UI for Remove Attribute. |
| 1248767 | Performance Delayed to locate snap points for 3D drawings. |
| 1248272 | LISP LISP routines to activate a page layout (Print configuration) in all sheets does not work. |
| 1245466 | Annotation (GTOL,Text,Leader) Any attachment is visible through mask in GA. |
| 1245315 | General Mac OS: Entities aren’t visible properly when using ‘PAN’ command. |
| 1242406 | Import/Export Unable to import the attached DGN files. |
| 1241353 | Print ‘MONOTXT’ textstyle does not print correctly. |
| 1240935 | Annotation (GTOL,Text,Leader) 2023 SP0:Hyperlink Ok button is not getting active after selection. |
