2023 SP2 Release Notes
Please see below the list of improvements:
SPR
Brief Description
1248331
DraftSight Mechanical: Resolved issue of closing DraftSight Mechanical when you delete available components from BOM setting.
1248273
DraftSight Mechanical: Resolved issue of closing DraftSight Mechanical when you add a column to BOM.
1247491
DraftSight Mechanical: Resolved issue when you add a column to the ride side of last column in BOM.
1247489
DraftSight Mechanical: Resolved issue of adding BOM column entries in the selected column.
1247250
DraftSight Mechanical: Resolved issue of adding new entries to BOM.
1247249
DraftSight Mechanical: Resolved issue of closing DraftSight Mechanical when you add a row to BOM.
1247134
Fixed DraftSight crash when you resave an existing DXF file that is saved with R14 format.
1247124
Resolved issue with the change in color of the available component property row for BOM tab.
1247120
Resolved issue with the BOM quantity value
1247117
Resolved issue when removing all BOM entries simultaneously from BOM setting dialog box.
1247094
Resolved issue when restoring the BOM settings when you click Restore Default.
1247018
Resolved issue when invoking Expression Builder dialog box.
1247016
Displays correct name of Balloon tab setting button.
1247015
DraftSight Mechanical: Resolved issue when displaying Help for BOM setting.
1244825
Resolved issue of memory free up when the drawing file is closed.
1244816
Resolved issue with displaying non-applicable toolbar options in the Toolbar list of Standard, Professional and Enterprise Packages.
1244750
Resolved issue while displaying the entity that is added in an existing block reference using 'Add components' command when you exit block editing session.
1244748
Resolved issue of the not allowed sign when inserting a block from design resources.
1244533
Fixed crash when opening multiple drawing files using Open with DraftSight context menu.
1244467
Resolved issue of Drawing line that changes its position after print in pdf.
1244091
DraftSight Mechanical: Fixed crash when using Mechanical layer with given workflow.
1244073
Resolved issue of the lag of mouse pointer.
1243614
Resolved issue when resizing DraftSight window or other dialog boxes.
1243604
Resolved issue with dark icons set for panels in the user interface customizations when you switch to dark mode.
1243538
Fixed crash when editing block in the attached the DWG file.
1242199
Resolved issue when you start DraftSight with a custom profile using DraftSight shortcut.
1241881
Resolved issue when displaying annotation correctly.
1241833
DraftSight Mechanical: Resolved issue with new BOM settings to allow users to select which properties to display in their Bill of Material, Part Lists, and Balloons.
1244281
DraftSight Mechanical: Resolved issue with Unit conflict dialog box to appear in dark mode for dark user interface.
1239311
DraftSight Mechanical: Resolved issue with Use color and lock option from Mechanical content > Visibility Enhancement.
