2023 SP0 Release Notes
Please find below the list of improvements in 2023 SP0:
SPR
Brief Description
1239004
Resolved issue when activating the SolidNetwork license on Mac.
1238785
Resolved issue in Transparency functionality in Export PDF.
1238318
Resolved issue opening a new file when PDM Addin is active.
1238114
Resolved issues in displaying DraftSight window and accessing the ribbon menus after you restore and maximize DraftSight window several times.
1237944
Resolved issue with the overlapped display when you move DraftSight window from one screen to another.
1237906
Fixed crash with DDKERNEL.DLL when printing in Czech language.
1237864
Fixed changing the drawing views, Left or Right.
1237819
Resolved issue in line weights of drawing when printing to PNG or JPEG format.
1237811
DraftSight lists all supported languages correctly.
1237311
Fixed crash when opening DWG files.
1237302
Resolved issue when zooming in the text that is present either in both model and sheet or in multiple block instances.
1236718
Resolved issue with the Recovery option.
1236640
DraftSight Mechanical: Resolved issue with Filters.
1236412
File specific: Fixed crash when opening a specific DWG file that contains xrefs.
1236230
Improved quality when displaying a polyline when its Global Width is changed to a non-zero value.
1236214
Resolved issue with the dimension format of a file when you save the file with a different name.
1236006
Resolved issue with table after saving a DWG file as R2000-2002.
1235851
Resolved issue when specifying the active directory other than English United States for spell check.
1235591
Corrected the Help content about supported SAT versions to import.
1235148
Resolved issue when trimming or extending multiple files simultaneously.
1235142
Resolved issue when restoring the DraftSight window.
1235051
Resolved issue with the line width when printing to PDF with multiple sheets.
1234961
Resolved issue with the dimension palette when entering more than one letter.
1234738
Resolved issue with retaining the created date of a DWG file when you resave the file.
1234355
Resolved issue with Multileader style when saving a DWG file as R2000-2002.
1234194
Resolved issue when printing the text using TTF font.
1233485
Resolved issue when displaying the Home tab when disabled for DraftSight Standard.
1232449
Resolved issue with the LISP file in DraftSight.
1231526
Resolved issue when displaying DraftSight when you maximize DraftSight window and use dual monitor.
1231172
Resolved issue when selecting the end point of the dimension line that is attached to the block entity or patterned entity.
1229538
Resolved issue with the displacement or deselection of entities when you click or turn off the Enable click and Drag option.
1229229
File Specific: Fixed crash when using rotate and scale operations on the file in DraftSight.
1227857
Resolved issue of removal of constraints from the file when you copy the entities.
1227592
Pickstyle icon works properly from the quick access toolbar.
1225844
Resolved issue when editing a field that is linked to the attribute.
1225119
Resolved issue with the name of the Print Configuration when its name contains a dot(.).
1216345
Resolved issue with the data type in the table cells of the table that is created in an older version of DraftSight when editing that table.
1216224
Resolved issue with customize ribbon tab when you restart DraftSight.
1215954
Resolved issue with the option 'shx text as geometry' when printing a DWG file to PDF format.
1211588
Resolved issue to change the centermark size when changing the dimension scale factor for an active dimension style.
1210635
Resolved issue with the print window when switching to printer to PDF.
1208424
Resolved issue with the Quick Input box when using relative coordinates in copy command.
1208147
Resolved issue with the location of Base Point when the Edit Blocks are originated from third party software.
1206507
File Specific: Resolved issue with the text on the notes on Xref when elements of another DWG are copied in the drawing.
1200045
Resolved issues with the corrupt .eps files if the default printer is set to a printer other than PDF printer.
